Kegger mod
Old Jan 26, 2008 | 12:27 PM
frogsr1's Avatar
frogsr1
Default Kegger mod
Hello
I am looking at the Kegger Mod does it move the torque band or does it open the band up? for you have done this Mod what are the pros ( is this a mod that only works if you do other Mods too?) and is there any Con of this mod
Old Jan 26, 2008 | 12:47 PM
BIGRED97's Avatar
BIGRED97
Default RE: Kegger mod
Ive been wondering the same thing. hopefully i will get to do a complete tear down and overhaul in the next month
Old Jan 26, 2008 | 01:27 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: frogsr1
Hello
pita if you dont have the proper tools. Cant quite say I even know if there are proper tools.Its just a pita.Depending on what you want to do, the general idea is that it increases velocity if you cut the runners and the divider. Really no point unless you are doing something that would necessitate that.
Old Jan 26, 2008 | 01:43 PM
frogsr1's Avatar
frogsr1
here is what i am thinking i have money coming in and i am planing on doing mods at one time Fast man TB Plenum Plate morpar air hat some kind of programmer spark plugs and themastat. guting the cat or high flow here are the ones i am not sure on if i am doing water pump, timing chain,kegger mod
Old Jan 26, 2008 | 01:49 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: frogsr1
If thats all, dont worry about spending the time on cutting up the intake. You can mess it up really well if you dont know whats going down charlie brown.
Old Jan 26, 2008 | 01:59 PM
xskylinedx's Avatar
xskylinedx
PITA! My uncle and I put mine on the mill and took an inch off. Probably could have gone more with it being a 5.9 but I was worried about losing bottom end. Still had to clean it up with an air grinder and I got sof'n sick ofit that after it came off the mill I didn't take another picture. Did it help? well I like to think so lol.
Old Jan 26, 2008 | 02:19 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: xskylinedx
took an inch off the runners? did you try cutting the center plate down to the base. THATS a pita!
Old Jan 26, 2008 | 02:49 PM
xskylinedx's Avatar
xskylinedx
I think its all PITA. With the setup on his mill the center would have been easier for me if I had to do it. I'm glad I didn't have one though.
Old Jan 28, 2008 | 07:56 AM
HankL's Avatar
HankL
MPI manifold without any plenum plate/gasket/bolts
seems a better way to go
for higher rpm power gains
http://www.steigerperformance.com/benefits/
Old Jan 28, 2008 | 08:21 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: HankL
yep. the m1 is very agressive for a stock motor though, even a little too agressive for me.
