Does the A/C suppose to kick on when....
Old Jan 26, 2008 | 02:15 PM
rtaylor's Avatar
rtaylor
Default Does the A/C suppose to kick on when....
Is the a/c suppose to cycle when your running any of the heat settings?? I have noticed that my a/c will cycle if I have the heat on and say have the heat settings somewhat turned down??? The only time it will not cycle is when I have the controls turned to off, is this all correct?? Looks to me as long as the a/c cycles its going to hurt gas mileage some but when its been 15 degrees outside I still have to adjust the temp settings these Dodges have GREAT heat!!! Any ideas?? Thanks
Old Jan 26, 2008 | 02:16 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: Does the A/C suppose to kick on when....
It does turn on when you put it on defroster or defroster/legs if thats what your talking about.
Old Jan 26, 2008 | 04:16 PM
IceCreamNazi's Avatar
IceCreamNazi
Yeah, I have the same thing happening to mine aswell. I was told it is normal. Let's waitfor the experts to weigh in on this.
Old Jan 26, 2008 | 09:34 PM
cvalcik's Avatar
cvalcik
Most newer vehicles use the ac compressor for defrosting.
Old Jan 26, 2008 | 10:12 PM
spaz_22's Avatar
spaz_22
you ac turns on becuase it dehumidifies the air. So you won't fog up your windows
Old Jan 26, 2008 | 11:08 PM
Sirhilton17's Avatar
Sirhilton17
Mine does that too...
I was told there is a moisture sensor somewhere in the ducts that senses the humidity... if theres alot of humidity it will do that... It will also do that no matter what if its on defrost...
If thats true, about the sensor it makes since... my heatercore is bad therefore adding extra humidity and the sensor can pick up on it hence why it does that all the time.
I have my a/c un plugged right now to stop it from doing that for the winter (heater core is so bad, ac doesnt help the window fog... I just deal with foggy windows and bad heat)
Old Jan 27, 2008 | 02:55 AM
MMGoose's Avatar
MMGoose
My 01 1500 does it too, drives me crazy.............[:@]
Old Feb 3, 2008 | 11:50 AM
X2K's Avatar
X2K
so has anyone resolved the issue?
My 2000 does the same thing, and its loud and annoying.
