Band Adjustment "Backing Off" TRICKS!!!
Old Mar 2, 2012 | 02:31 PM
  #21
Crackshot's Avatar
Crackshot
Originally Posted by mcweaver
someone stated that many of us have issues AFTER adjusting the bands. When my transmission got rebuilt about 2 months ago I specifically asked about adjuting bands when I service the trans and the response I got was don't do it unless something is wrong. I'm not saying they are right, all I'm saying is they are professionals and that was the advice I was given. Since then I have asked other mechanics that I trust and they all say the same thing? So maybe this was a habit that was formed at some point because of an issue that isn't needed anymore? I'm not sure what I'm going to do when it's time to service it!
I think bands are supposed to be adjusted every 50k is what I thought maintenance schedule was. Could be wrong.
I know it is at 100k maintenance schedule.
Old Mar 2, 2012 | 02:37 PM
  #22
zman17's Avatar
zman17
Retired Moderator - RIP
You are right, there is a maintenance schedule to adjust them. But if someone does not have the right tools, or has not done the homework, they need to let a pro to do it.
Old Mar 2, 2012 | 04:09 PM
  #23
johnnyjaws98's Avatar
johnnyjaws98
Found a socket that worked . changed the filter and fluid and ajusted the back band gos in to reverse much stronger now and bearly makes any noise now .didnt get to the front band yet .Also replaced the check ball line with some coolerr line i got from the store
Old Mar 4, 2012 | 08:52 PM
  #24
98dodgeram1500(5.9L)Laramie's Avatar
you can always use a wrench. dont have to use a socket. by using a wrench you will still be able to count the rotations an know when to stop.
this is a link to a site i use and has helped me with my truck problems http://dodgeram.org/tech/transmissio...T_band_adj.htm
Old Mar 4, 2012 | 09:43 PM
  #25
Augiedoggy's Avatar
Augiedoggy
I was given the same advice...I was told due to the design of the bands in our transmissions if they are at the point where the band is causing it not to shift right adjusting them wont help at that point...They are so thin and have such little clutch material on them its crazy they hold up as long as they do... the transmission guy said on these transmissions adjusting them is actually more likely to just cause problems and premature wear...
Old Mar 4, 2012 | 10:36 PM
  #26
jswain's Avatar
jswain
The two nearest Chrysler dealerships both said they do not adjust the bands when doing a transmission service when I asked a couple of years ago. So I asked my favorite local mechanic and he also said not to adjust the bands unless the trans was slipping, and at that point it would probably not help anything. So, I never adjust the bands. Of course my transmissions don't last that long either lol.
Old Jul 17, 2012 | 11:02 PM
  #27
peiyeller's Avatar
peiyeller
my 2001 2wheel drive dodge with a cummins has a very soft 2nd and 3rd shift wondering if a band adjustment might help this condition? Would appreciate any insight given all other gears seem fine
  #28
Sure can't hurt, especially if it has been a while....
Old Jul 17, 2012 | 11:11 PM
  #29
gdstock's Avatar
gdstock
Changing solenoid and pressure sensor and upgrading with a Sonnax Sure Cure couldn't hurt either.
Old Mar 27, 2018 | 11:27 PM
  #30
Brian Flowers's Avatar
Brian Flowers
Originally Posted by IndyRamMan
sorry I cant help you on this, but Im all ears on this one. Id like to pickup anything about band adjustments.
I have a 46 RE OO" for the back off its 2 1/2 counter turns.
