*Post Header Install/Symptoms* (Fresh Start)
Here an idea , did you ever think that maybe the CEL light bulb is burnt ? or maybe the last person who sold the truck knew there was a CEL and took the bulb out ??? These could be why you are not seeing this.
ORIGINAL: padodgeram
it will end up fine in the long run, this is just one of those problems that are easy to fix, but are easilly overlooked. id say start with and o2 sensor and tune up and go from there.
let us know what happens
Sometimes there are codes that are stored that dont throw a light.
List for me what you or your mechanics have tried so far...because as far as I can tell, no one has tried anything to fix it...just turned you away.
Does the CEL light up whn you start the truck? I don't know if you said that or not... 132 and 138 are O2 sensors.... nobody makes one that has longer wires? When you had to have it spliced, did they splice the wire between the sensor and the connector? or between the connector and the pcm? If it's between the sensor and the connector... maybe you can reroute the wires from the pcm to the connector so that you get a little more slack... IDK just my .02 hope you get this thing going it's a good truck!
I dont understand something.. You said you want it to run like it use to, which would be stock, Yet you want a loud powerful sound...No offense but why get headers just for the sound??
HOLY FUKING ****!!!!!!!!!!!!!!!!!!!!! put some o2 sims on the bitch, and call it good ... if that will work.....seems like you aint getting nowhere with this, what can be so bad that "nobody wants to work on your truck?!!!!!!!!!!" if it was me i would put the old manifolds back on(which im sure you dont have and the exhaust shop threw them away)and get new o2 sensors to see if thats fixes the problem.... start back at square one............[sm=badbadbad.gif][sm=bomb.gif][sm=dontgetit.gif][sm=headbang.gif][sm=icon_beat.gif][sm=icon_rtfm.gif][sm=icon_rtfm.gif][sm=icon_rtfm.gif][sm=icon_rtfm.gif][sm=icon_rtfm.gif][sm=icon_rtfm.gif][sm=icon_rtfm.gif][sm=imsorry.gif][sm=jawdrop.gif][sm=jawdrop.gif][sm=jawdrop.gif][sm=jawdrop.gif][sm=shootshoot.gif][sm=violin.gif][sm=wtf.gif][sm=WTFsgign.gif]
ORIGINAL: xskylinedx
Its not like its pig rich, I can just tell its a little rich. No offense (seriously) I'm just not in the mood to fight about it. Mechanics I've talked to that work on Dodge tell me thata badrear O2 will cause the truck to not run ideally. That it will f the mixture up because the front and rear need to work together. I got the feeling your definately right about a rear O2 (or sim)not fixinga super rich condition.
20DodgeNeon
When you get the truck back the first thing you need to do it this. Hold the odometer reset button down and turn the igntion on. Watch wich lights come on. Check for the light that looks like an engine. If that dosn't come on then you have a burnt bulb and there could have been other codes that you didn't know about before you reset the PCM.Next turn the key off and then back to the ignition on postion three time then watch the odemeter and write down any codes you get.Next go down to the tool shop and buy an O2 remover. It's basically a funny shapped socket. Then Jump under the truck and switch the rear O2 sensor with the Front O2 sensor and see how it runs. Don't just switch there positions. Dissconect them and reconnect them in the differnt positions.IT should only take about 15-20 mins. Then reset the PCM. Then drive the truck and post your results. If you don't do this then there is nothing this forum can do for you. This is one of the first dignostic steps to find out what is wrong with the truck. I understand you don't have time or money for alot of crap but you are spending way more time and money by not trying these basic steps.
