Desperately needed: CTM (central timing module)
Old Feb 3, 2008 | 06:06 PM
petekf4qoe's Avatar
petekf4qoe
Default Desperately needed: CTM (central timing module)
Desperately needed: CTM (central timing module) I am in desperate need of a CTM (central timing module) for my 1998 Dodge ram 1500. My truck has all of the options, PW, PDL, PS, Electronic dimming rearview mirror, heated outside mirrors, Infinity sound system, main domelight, seatbelts. I am sure there are many other things too but I have not found any that are affected. Ok if anyone has one that they would part with cheap please let me know.
If you have any other ideas as to what may be causing my problem please chime in. But dont mention fuses or breakers as I have been through those a hundred times already both under the dash and under the hood.
PLease visit my 2 other posts for mor info on my problem.
https://dodgeforum.com/m_1052909/mpa...tm.htm#1071690
this post here by dhvaughan told me that the problem is most likely located in the CTM.
https://dodgeforum.com/m_1149395/mpa...tm.htm#1150037
Any help would be greatly appreciated.
Thanks
Old Feb 4, 2008 | 01:21 AM
rabbler's Avatar
rabbler
Default RE: Desperately needed: CTM (central timing module)
Do you know what part # yours is.
I think I have a brand new one in a box but I cant remember what year it is from. I think 99 or 2000. might be the same
I'm away from home for 2 weeks so I cant check it for you.
Old Feb 4, 2008 | 07:41 PM
dhvaughan's Avatar
dhvaughan
i have part number 56020157AC from '01 1500 ST thats not doing anything except collecting dust.
let me know if that's your number.
Old Feb 6, 2008 | 01:25 AM
petekf4qoe's Avatar
petekf4qoe
Hey thanks for the reply. I am sick as a dog right now with the flu, so I will check the part number on it when I get to feeling better. I talked to a few friends who know a lot about Dodges and they said it should work no problem. Give me a few days to get to feeling better and I will post back then with the number. Again thanks a lot
Old Feb 6, 2008 | 12:45 PM
Parts/Service's Avatar
Parts/Service
There are 2 different "timing and control" modules depending on if it has integrated keyless...
56020157AC without keyless intrgrated
56045202AA which changes to 5015246AA with keyless integrated
Old Feb 6, 2008 | 02:50 PM
petekf4qoe's Avatar
petekf4qoe
Ok, Thanks for the info. Mine does have the keyless entry. So if I read your post right I would need "5015246AA" Is that right? I thank you so much for helping with this information. This has been a nightmare trying to figure out. I am so hoping this solves my problem as the worst part of this is I cannot wear my seatbelts and I am afraid I will get a ticket which here costs a huge amount of money that I cannot afford to pay.
Old Feb 9, 2008 | 07:29 PM
petekf4qoe's Avatar
petekf4qoe
Ok, I have found out which CTM I need. The original part numberin mytruck is 56045202AA,that has changed to a new number 5015246AA.This is the Dodge parts part number. If anyone has either one of these please let me know.
Old Feb 13, 2008 | 09:36 AM
petekf4qoe's Avatar
petekf4qoe
anybody got one?
Old Feb 13, 2008 | 11:19 PM
rabbler's Avatar
rabbler
I'll be home tomorrow and check mine for you
Old Feb 14, 2008 | 12:29 AM
petekf4qoe's Avatar
petekf4qoe
ok thanks
