Where to get M1
Old Feb 4, 2008 | 12:30 AM
hometheaterman's Avatar
hometheaterman
Default RE: Where to get M1
Anyone have a link to the Edlebrock one? How big of a performance difference will I see with these? I have always planned on going with one of these eventually and eventually maybe a Fastman TB but now I'm wondering if I wouldn't be better off to go with the APS kit. If I won't see much of a difference it might not be worth the extra money. Wayne is familiar with me by now I'm sure as many times as I've called about my Tranny and with the problems with UPS being slow or losing not sure which the converter.
Can anyone give me an idea on what it would cost to have it replaced if I get the APS kit and Orings? So basically I would just need labor. I just had my water pump and t-stat replaced not long ago at all although I put a stock t-stat in so maybe I should change to the 180. I'm just afraid it will make me have no heat at all which I like having. The heat is already not as hot as it should be which is why we changed the water pump and t-stat. The mechanic said that the water pump wasn't putting out enough pressure.
Old Feb 4, 2008 | 05:37 PM
beaner's Avatar
beaner
the m1 is a great intake. the only only real problem is with the short runners you lose low end torque. the intake are about 1/3 the length of the stock beer kegs. you can make up the lowend torque with a taller gear. if you go with the 4 barrel be prepared to have to machine the injector ports and drill andtap some misc holes for brackets. the 2 barrel already has this all done. it is a direct bolt on and is good for about 435 to 475 horse. as for the t-stat i put a 160 in my truck and there was not enough heat.the 180 t-stat works just fine it has plenty of heat and does not cook me out in the summer.
Old Feb 4, 2008 | 08:57 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Silver_Dodge
Get the 4 barrel M1. It's cheaper then the 2 barrel and said to perform better too, and you can just use the adapter plate to convert it from carb to throttlebody.
your retarded. sorry.
this is all dumb. Just fix your plenum if you have a leak. Just because something isnt factory doesnt mean your going to get power from it. (and even if you do, doesnt mean your getting it in a useable range)
Old Feb 4, 2008 | 09:01 PM
Silver_Dodge's Avatar
Silver_Dodge
Why do you say that? I was serious. It is almost $200 cheaper, and you can get it already converted to use with our trucks. It is good for over 600hp. Contact John Mercedes at southeastrt.com, he'll tell you the same thing.
Old Feb 4, 2008 | 09:05 PM
IndyRamMan's Avatar
IndyRamMan
$200 - 50 for the adapter and the to have someone drill it for mpi. Ontop of that....its still an M1 Unnessissary for a next to stock motor. Thanks for the contact, but Im not going to call John. I have no need of getting advice from people when I already have the answer.
Old Feb 4, 2008 | 09:24 PM
hometheaterman
Not saying that either of you are wrong as you are probably right about it not being worth it on a stock motor but I have to say I think Silver_Dodge knows quite a bit so I tend to listen to him.
Old Feb 4, 2008 | 09:40 PM
Silver_Dodge
ORIGINAL: IndyRamMan
Whatever dude. He and I have discussed on several occasions using the M1 on stock and mild performance engines (like the Dakota R/T's and Magnums modified like mine is). I think i'll listen to the guy that has his own high performance shop and has built tons of high performance Magnum engines and has even engineered parts for them. They've dyno tested hundreds of combinations of parts on stock to highly modified engines and know what works and what doesn't. How many have you built. One? Has it ever even seen a dyno more then once, if at all?
Sure, if you have everything bone stock, then the M1 is probably not the right mod to do right out of the gate. But don't believe the same old hum drum that the M1 is only good on 408's making 600hp either. Some day, i'll try an M1 for myself, and I will be able to say definitivly that it is better or worse then the stock intake. For now, i'll listen to the experts. Have you tried both yet to back up your comments? If not, stop making claims as if you know all there is to know on the subject.
Old Feb 4, 2008 | 09:54 PM
IndyRamMan's Avatar
IndyRamMan
THIS IS WHAT WE ARE TALKING ABOUT....not your 600 horse pie in the sky. Talking about reality vs fantasy. Get your head out of the clouds. I dont know when Iv ever said the M1 was trash or anything like that...you build accordingly to what you have done.PERIOD.
I dont need to try everything to know what works and what doesnt. I dont need to try a 60+hp chip to know its a crock of **** do I? Have you tried every header and exhaust combo there is out there? If not, by the same logic, you shouldnt EVER talk about exhaust again.
A little side note about mechanics....we all remember how much of a hot rodder Neon's exhaust mechanic was....dont we.
Lets see what youve said in this post.
which one is it oh tech certified master?
Old Feb 4, 2008 | 10:00 PM
padodgeram's Avatar
padodgeram
In a month ill have an M1 on my truck and ill let you all know what i think....
Old Feb 4, 2008 | 10:05 PM
zddp8868's Avatar
zddp8868
its the same exact thing with putting a high rise single plane intake on a stock 283. hmm... NO.
an intake manifold could increase power, but never significantly. an intake manifold doesnt make power. what makes power? CAMSHAFT. CYLINDER HEADS.
PERIOD.
