Old Aug 7, 2015, 12:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine
Print Wikipost
Kegger Intake Mod DIY
Old Oct 30, 2011 | 11:47 AM
  #291
Originally Posted by bwdakrt
I could be wrong but I thought would put the tranny in limp mode and you would only have 2nd gear?
Disconnecting the PCM from the trans disables everything. It simply won't shift. At all. It stays in whatever gear you put it in. Even the TV cable won't make it shift. I don't know enough about how the trans actually operates, but, this method is used as a test for the governor pressure sensor/solenoid. If it will manually shift thru the gears with the PCM out of the loop, but, is in limp mode, or behaves oddly with the PCM hooked up, either the sensor, or the solenoid, or both... are bad.
Old Oct 30, 2011 | 12:15 PM
  #292
aim4squirrels's Avatar
aim4squirrels
I thought 3rd gear was limp in, as its the 1:1 and keeps careless drivers from abusing the RPMs on a malfunctioning Trans?
Old Oct 30, 2011 | 12:28 PM
  #293
Not sure, thought limp mode was 2nd? Hopefully, I won't figger that one out by direct experience.
Old Oct 30, 2011 | 12:54 PM
  #294
bwdakrt's Avatar
bwdakrt
Read the last line in the answer.
http://en.allexperts.com/q/Dodge-Rep...-limp-mode.htm
Old Mar 5, 2012 | 08:07 PM
  #295
ramthis9501's Avatar
ramthis9501
Old thread but got a question... I have an extra intake laying around that I want to do this to. Its from a 95 Ram but I have an 01. I know theres a few things different between the two, so what do I need to do to make it work?
Old Mar 5, 2012 | 08:32 PM
  #296
Augiedoggy's Avatar
Augiedoggy
You need to plug off the egr valve port and remove the center divider... be careful how much you remove.... dyno results have proven this mod just takes HP from the lower end and moves it up the rpm range... the more you trim from the runners the more power you lose in the lower rpm range.
Old Mar 5, 2012 | 08:35 PM
  #297
ramthis9501
Ok about an 1" to 1.25" off the runners is good enough right?
Old Mar 5, 2012 | 08:55 PM
  #298
ramthis9501
Also how do I plug the egr valve?
Old Jun 5, 2012 | 09:45 AM
  #299
keilkravec's Avatar
keilkravec
ok question, i will be doing this on most likely an egr keg, the long runners are meant to better the low end power, what might i expect by cutting out a majority of the divider (leaving some as its function of tube support) and not touching the runners for a 5.9? Any difference? Or is the real gain only made from trimming the runners? Aiming for 2k-6k cam so would enjoy having the low end still since 1800 to 2000 is my od range at cruise.
Old Jun 5, 2012 | 09:49 AM
  #300
That cam won't work worth squat with the kegger. Kegger is designed for low RPM grunt, and a bit of midrange, falls flat on it's face north of 4000 RPM. You won't be happy with that combo.
If you want to run that cam, go for the Hughes AirGap, or the Mopar M1 two barrel manifold.
