Stroker Kit ?'s
Old Feb 5, 2008 | 10:14 AM
Ram2K1's Avatar
Ram2K1
Default Stroker Kit ?'s
Hey all...
I have a few questions about KRC stroker kits.
1. Why is the 408 cheaper than the 390?
2. What kind of hp increases can be expected with each?
3. Would there be a need to change anything else (internals)in the motor?
4. What's the difference between "balanced" and "unbalanced" kits?
5. Which kit would be better for a DD?
I think that's all.
Thanks.
Old Feb 5, 2008 | 12:07 PM
pcfixerpro's Avatar
pcfixerpro
Default RE: Stroker Kit ?'s
Well I do not know from experience, so I can't give you hp increase etc.. As far as changing the internals, just depends how far you wanna go. The kit should change your crank, pistons etc, but.. i mean if ya wanna work on your heads, cam, etc. Being balanced and unbalanced, the 318 is internally balanced, and 360 is externally balanced by ... wtf is that thing called... ____ dampener??... wait, Harmonic balancer, and I think the 360's use a different fly wheel. Better for daily driver.... your 360.
Good luck!
Old Feb 5, 2008 | 12:13 PM
Ram2K1's Avatar
Ram2K1
So the 360, since it is externally balanced, would need the unbalanced kit? Thanks for the info... I guess with the question about internals, what I'm really asking is: Could you install this stroker kit and not change any other parts except for what comes in the kit and be okay?
If I do this, it will be a couple of years down the road...just like to know ahead of time.
Old Feb 5, 2008 | 01:54 PM
1BigRamaniac's Avatar
1BigRamaniac
I know there are books out there that tell about how to do this. I think they are called Making Horsepower for small (or) large block Mopar. Sell for around 20 bucks.
