Which valve spring for R/T cam?
Old Feb 6, 2008 | 03:57 PM
Dan1071's Avatar
Dan1071
Default Which valve spring for R/T cam?
I just got a R/T cam dirt cheap and was wondering what is the best valve spring to use and where to get it from? I am rebuilding my 5.9 360 engine and not looking to do a extreme motor, but daily driver with towing, good overall runner. I have already checked WholesaleMopar.com and was wondering if there are any other options equivalent.
Rebuilt bottom end
Doing the kegger modification and upgrading the plenum plate
Stock heads
Manum R/T cam
Stainless shortie headers
Magnaflow high flow cat
Dual exhaust out mufflers
Underdrive polished pulleys
Mopar Double Roller timing chain
Plan on Fastman TB
Old Feb 6, 2008 | 06:40 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: Which valve spring for R/T cam?
I dont know which R/T cam you are refering to, but the 4876062 springs are rather good for a little higher lift. Great open pressure of about 360, so you get a little less wear on your valves and seats.
google moparts
Old Feb 6, 2008 | 07:14 PM
Dan1071's Avatar
Dan1071
The camshaft I got had p/n p5249549. The books I have say p/n p5249464 valve spring is recommended. Which spring is best for this application?
Old Feb 6, 2008 | 07:38 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Dan1071
thats a fine spring for the lift. .525 bind with a cam thats 467 max. general rule of thumb is that you want approximately 1/16th of an inch diffrence btwn bind hight and max lift. (cam lift is measured in tenths of inches incase you didnt know or figgure out yet) so .500 is 1/2 inch or 8/16th.
Old Feb 6, 2008 | 08:35 PM
zddp8868's Avatar
zddp8868
ORIGINAL: Dan1071
indy is right you want at least .060 clearance... id go with those recommended springs or comp cams 901-16 springs. they are good to .550 lift if you decide to get a larger cam down the road.
Old Feb 6, 2008 | 10:03 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: zddp8868
ORIGINAL: Dan1071
+1
the 901 has a decent open pressure too. Its the cheeper alternitive.
Old Feb 6, 2008 | 10:22 PM
zddp8868's Avatar
zddp8868
ORIGINAL: IndyRamMan
ORIGINAL: zddp8868
ORIGINAL: Dan1071
+1
got ur back, jack! [sm=icon_cheers.gif]
PS: and in my opinion, the BETTER alternative
