Plug Wires--->
#32
#33
RE: Plug Wires--->
ORIGINAL: Ram2K1
Looks like they come with wire holders AND numbers to identify each wire...if the image is correct. They do look like sweet wires, especially for the $$$...I'm pretty much sold...
#34
RE: Plug Wires--->
Hold on I will check on the part #. I assume the ones I have now ready to go in are the same ones in the truck. I just asked Advance for the stock Champions in the past. This time I went to Napa but did the same. The ones I have waiting to go in are RC12LC4 over top of that number they have a 436.
They were $1.39 a piece at Napa. It's been a while since I got them from Advance so I don't know what they cost there.
#35
RE: Plug Wires--->
ORIGINAL: hometheaterman
EDIT: The NAPA part # is CHA-436 for the regular copper plus...part # CHA-4436 for the copper "truck" plugs. They are about a buck more per plug, but I may go with the truck plugs. Summit says the core is much bigger on the latter.
#37
RE: Plug Wires--->
ORIGINAL: Ram2K1
Screw that...takin em back. What P/N are the Champions everyone seems to like?
Btw, Rammaniac, I have no problem spending other peoples money, so if you have any other questions, ever, just ask
#38
RE: Plug Wires--->
ORIGINAL: Jr. Mechanic
NOOOOOOO! lol. There are TONS of people that have have those plugs in their 360/318 and love 'em. I have them in the Dakota with the 3.7 and I could imediatly tell a difference. Two months later it is still running great and the sis said she has gained 2mpg.
ORIGINAL: Ram2K1
Also, I got an email back from Jegs. They said yes, even though it says 1994-2000 for those plug wires (part # 555-40251) they WILL fit 2001 models as well. They also said they are a bit longer than the OEM wires and designed to fit in the factory looms for easy routing.
#39
RE: Plug Wires--->
So any advantage to going with the truck plugs? If so I will take mine back and get the others.
These Champion truck plug spark plugs have been specifically designed for the severe demands that pickup trucks and sport utility vehicles place on spark plugs. They feature a massive center and ground electrodes that are 20 percent larger than ordinary spark plugs, providing high conductivity between the gap and more dependable performance than ordinary spark plugs. Champion truck plug spark plugs use a zirconia-enhanced insulator that offers 40 percent more strength and provides durability and longer life under severe driving conditions. Electrodes on the plugs feature their exclusive Heat-Active alloy to reach operating temperatures quickly and maintain stable temperatures under varying engine loads. Choose these Champion truck plug spark plugs for maximum reliability under extreme driving conditions.
May be worth the extra cost. I called NAPA, and they said these were $2.89/ea.
#40
