Has anyone had trouble bolting on Mopars deep tranny pan? The holes dont line up correctly.
Old Feb 8, 2008 | 01:26 PM
Ray Salazar's Avatar
Ray Salazar
Default Has anyone had trouble bolting on Mopars deep tranny pan? The holes dont line up correctly.
tranny pan problems!!!
Old Feb 8, 2008 | 01:46 PM
hometheaterman's Avatar
hometheaterman
Default RE: Has anyone had trouble bolting on Mopars deep tranny pan? The holes dont line up correctly.
Nope I've seen pictures of them on but I don't have one. I kind of wish I had gotten one though. I may end up adding it later on. Where is the best place to get it?
Are you sure you have it turned the correct way and that you got the correct one for your tranny?
Old Feb 8, 2008 | 02:12 PM
Silver_Dodge's Avatar
Silver_Dodge
I've heard that they are not a bolt on deal. You have to do some fab work to make it fit.
Supply bolts, make up a filter stud mount, etc. You also have to grind on the pan and dremel
trim some tin baffles on the valve body to get pan on. That is why I didn't go with a Mopar
pan, and got one from PML instead. Perfect fit.
Old Feb 8, 2008 | 03:08 PM
GOD RAM IT's Avatar
GOD RAM IT
it will not work on the RE trannys the cooling fins will hit the solenoids and such and the pan isnt any deeper than the stock oone. its just aluminum.
been there done that
Old Feb 8, 2008 | 03:31 PM
hometheaterman
Didn't DJ Gaston get one on his tranny from APS back several years ago? His was a 46RE I think. If I get a deep pan which one should I go with?
Old Feb 8, 2008 | 09:02 PM
RM_Indy's Avatar
RM_Indy
Ive got the Mopar deep trans pan. 2min of grinding andinstall the suppliedsump extension and it fit just fine. It is deeper and holds 2quarts more than the stock did.
Old Feb 8, 2008 | 09:09 PM
RM_Indy's Avatar
RM_Indy
Are you sure you have the right pan?Couple dealers I went to kept trying to sell me the wrong pan.
Old Feb 8, 2008 | 10:36 PM
hometheaterman
If I get a pan do you know which one I want? What did you have to grind? Did it come with a drain plug or do you have to add that?
Old Feb 11, 2008 | 09:38 AM
GOD RAM IT's Avatar
GOD RAM IT
indy which truck did you put the mopar one in? I got one and put it next to my stock one on my 98 and there is noway it was 2 quarts more. maybe it was 6 ounces. but not 2 quarts.
read this thread. I pretty much laid everything you need to know here.
https://dodgeforum.com/m_491239/mpage_1/key_/tm.htm
