PITA List
Old Feb 9, 2008 | 12:32 PM
WTL's Avatar
WTL
Default PITA List
The post below about the starter bolt gave me an idea for a new thread. Lets list all the royal pain in the *** parts/bolts/things that dodge egineered in our truck, because somehow complaining about such things makes me feel better about the hours of time I've spent screwing with a single bolt while cursing dodge engineers.
For me, what comes to mind first are
the location of the cap and rotor. I can't even see the damn thing when I have to fool with it
the EGR tube. Its way back behind the intake and makes putting the intake manifold back on much harder than the peice of cake job it would be otherwise.
So what pisses you off about dodge egineers?
Old Feb 9, 2008 | 12:50 PM
Cereal Killer's Avatar
Cereal Killer
Default RE: PITA List
Well it's not really a big deal, but I don't think it would have killed them to put a drain plug in the transmission fluid pan.
Old Feb 9, 2008 | 12:52 PM
rabbler's Avatar
rabbler
Cranks sensor and oil pressure sensor are definitely on my PITA list.
Fuel filter location and the fact some trucks don't have a fuel test port on the fuel rail makes the list too.
Old Feb 9, 2008 | 12:58 PM
nolazach's Avatar
nolazach
ORIGINAL: WTL
The funny thing is its so sad but true. At least I'm not the only one (I feel less of a mechanic, when I can't get a single bolt off)
Well the starter bolt of course, but also the fact that the starter has to come off to drop the oil pan is a PITA. I hear alot of bad stuff about the fuel pump too, and I think I will remove my bed when that day comes.
The dashboard is nearly impossible to remove.
Really I did the front end with no problems, changed the rear with little problems (I broke the bolt that holds the gear on and had to use an extractor).
Although I will make a list of everything that comes up here, this forum let me know the starter bolt was a PITA well in advance.
Old Feb 9, 2008 | 01:13 PM
heybuddy1901's Avatar
heybuddy1901
everything but the lug nuts.
but even some of those have managed to get cross-threaded and snap..
Old Feb 9, 2008 | 01:18 PM
motorbrreath's Avatar
motorbrreath
fuel tank bolts... next to the carrier bearing that makes it IMPOSSIBLE for you to get it off.
fuel pump in the tank...
4x4 vaccum actuator.
Old Feb 9, 2008 | 01:28 PM
1980blackfiveoh's Avatar
1980blackfiveoh
I'll add: fuel filter in the tank & TP sensor on a V10
Old Feb 9, 2008 | 01:43 PM
Tarner's Avatar
Tarner
front wheel hubs are a PITA the first time you have to change them out.
Old Feb 9, 2008 | 03:03 PM
nolazach's Avatar
nolazach
IDK about the other poster but my Lug nuts are definetly a PITA. I have had quite a few snap. Have replaced IDK maybe 12 of them so far. Not that hard but a PITA
Old Feb 9, 2008 | 03:34 PM
Jr. Mechanic's Avatar
Jr. Mechanic
HVAC box.
