e-fan
Old Feb 12, 2008 | 04:34 PM
sk8ordie's Avatar
sk8ordie
Default e-fan
ok now ive got some Q's on e-fans. does anyone have the perma cool direct fit e-fans? if so is it worth 570.00. Or does anyone have any e-fans on the 5.9 mag. does it keep ur truck cool? im just trying to find out cuz im in Phx, AZ and the summers here are 115 deg. and i dont want to overheat!! please help ive tried searching and cant find what im lookin for. thanx for the help!!!!!!!!!
Old Feb 12, 2008 | 05:51 PM
greenmachine's Avatar
greenmachine
Default RE: e-fan
If you are talking about the cool pak then yes I have one. I did not get a chance to see how it performs. I had to travel again. Sorry cant help you much. I can tell you that it is very well put together. The shroud has places to mount your wiper fluid and coolant tanks basically in the factory location. It also mounts to the existing mounts. Wires in easily. The hardest part is getting the mechanical fan off.
Old Feb 12, 2008 | 09:44 PM
sk8ordie's Avatar
sk8ordie
Default RE: e-fan
so is it worth spending that much money?
Old Feb 12, 2008 | 09:54 PM
Silver_Power's Avatar
Silver_Power
Default RE: e-fan
the question is.. do you think its worth it .. to me sounds kinda pricy.. but then again i havnt looked around at the E-Fans. Sorry Couldnt Help Much
Old Feb 12, 2008 | 11:35 PM
padodgeram's Avatar
padodgeram
Default RE: e-fan
build you own...
Old Feb 14, 2008 | 07:18 PM
sk8ordie's Avatar
sk8ordie
Default RE: e-fan
did u build ur own? does it keep ur engine kool. remembre the average temp in AZ summer is 115. i would like to know if i tworks
Old Feb 14, 2008 | 08:43 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: e-fan
I have e fans and live in Dallas this summer we hit 105* a few times and I never ran above 190* with a 180* tstat in heavy gridlock in Downtown Dallas.
If you go with a set of fans that can move anywhere between 4000 and 5000 CFM's you should be fine. Aim for the higher CFM's if you tow or load it down a lot.
Old Feb 14, 2008 | 10:56 PM
padodgeram's Avatar
padodgeram
Default RE: e-fan
ORIGINAL: sk8ordie
built my own shroud , fans are flx-210 rated at 2500 cfm bare mim that i would stick on a truck... as far as heat goes , ill let you know this fall...
Old Feb 14, 2008 | 11:14 PM
mr freeze's Avatar
mr freeze
Default RE: e-fan
http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
This is what I have been looking at getting.Then maybe doing a little surgery on the fan shroud to make it work.
Old Feb 14, 2008 | 11:20 PM
padodgeram's Avatar
padodgeram
Default RE: e-fan
how would you hang your tanks ??? something to think about..
