Wheel Sizes
Old Feb 13, 2008 | 11:33 PM
05DodgeRamHemi's Avatar
05DodgeRamHemi
Default Wheel Sizes
I've finally decided I will be getting new rims in the near future. I love the offroad editions, but they have a couple chips on the cirumferance of them from the previous owner, and I just like having things perfect. I think the size of the offroad rims are 17x8.5? That sound right? I wanted to know what size I should try and look for when looking for newer rims? I kind of want the rim to be wider so maybe the tires will still out just a little bit more. I like that 35/12.5/17 size, but wouldn't a wider rim make the tires stick out just a little bit more? Anyways, I just mean help me out with picking the right size in a 17 rim, how wide should I go. Thanks.
Any you guys are welcome to give me suggesstion with what looks good too would be a big help. I want the rims to be nice and shiny, yet look good on an offroad truck that tends to get muddy quite a bit.
Now here is a wheel I really like, and I think it would look really sweet in a 17" size. What do you guys think??
[IMG]local://upfiles/61042/57FE03DED52A4C5CAE6162B4FCC081C0.jpg[/IMG]
[IMG]local://upfiles/61042/765132E35E374C2F97E9070AE2972733.jpg[/IMG]
Old Feb 13, 2008 | 11:41 PM
pcfixerpro's Avatar
pcfixerpro
Default RE: Wheel Sizes
not quite sure I can help ya with what rim's to suggest, but I think the stock offroad rim is 17x8 as I recall. As far as the tire sticking out further, you can run the same tires you have with a different backspace and push them out or in. There are also a lot of sizes in the 16" variety that you could go to if your doing new rims. I wish ya luck!
Old Feb 13, 2008 | 11:46 PM
SilverRam_01's Avatar
SilverRam_01
or you can stack a few washers on each of the studs before you put the rim back on...
These are sick. The ones you want are all the way at the bottom of the list.
http://www.weldracing.com/wheels/det...loy%20Polished
*Those are sick! I love that look.
BTW you should do a KORE clone!!
http://www.off-roadweb.com/features/.../photo_01.html
Old Feb 13, 2008 | 11:53 PM
pcfixerpro's Avatar
pcfixerpro
I wouldnt stack washers imho, if I had too id run spacers. And even if I had to run spacers I wouldnt.... (already did on another vehicle) Just extra hassel. I put longer studs on etc cuz I didnt research the right backspacing etc. If your buying a rim, find one that fits!!!!!!!!!!! Dont be half **** and buy the rim then worry about how your gonna put it on like I did. Measure twice, cut once.
I put these rims on and had to use a 1/4" spacer to pull the front wheel out so it didnt hit the upper control arm or w/e. Now when you cut the wheel on a right hand turn, the wheel scrapes on the fender. She needs new coils springs and she'll be fine. heck she needs leaf springs too, but that aint my problem any more
[IMG]local://upfiles/60925/0E3E31D065F54A98A42CAABD493879AA.jpg[/IMG]
Old Feb 13, 2008 | 11:56 PM
SilverRam_01
^ I was just sharing some white trash insight.
Old Feb 14, 2008 | 07:44 AM
squishy_1010's Avatar
squishy_1010
I would check out 4wheelparts.com They have a set of Mickey Thompson Classic II wheels for $153.99 each in a 17x9.5. They have free shipping on wheels right now I think.I was going to get these wheels when I had my 4x4 Ram. I think they look pretty sweet.
OFF TOPIC but how did you change your screen name without starting a new profile?
Old Feb 14, 2008 | 09:40 AM
05DodgeRamHemi
I had Silver_Dodge talk to Devils_Reject, and then Devils_Reject hooked me up.
Old Feb 14, 2008 | 12:12 PM
Cereal Killer's Avatar
Cereal Killer
If you're going to go with a wider wheel make sure you get one with better backspacing since you're already having trouble with rubbing on the control arms. 8" is wide enough for a 12.5 wide tire, but if you do get the 10" just make sure you get the extra backspacing to compensate. Plus with 10" wide wheels you can get 14" wide tires next time you get tires
One question Neon... Do you love your ball joints?
Old Feb 14, 2008 | 12:19 PM
TheForce55555's Avatar
TheForce55555
If you bring the tires out to far from underneath the truck, your gonna be eating wheel bearings and ball joints like a Mother *****
Old Feb 14, 2008 | 12:41 PM
IndyRamMan's Avatar
IndyRamMan
Idk if you can get tailgunners in 17s, but check them out...they look SAAWHEEET! (you might also look into whatever the model of amer. racing wheel is that is black, it might go well with your truck)
