ABS Rocker Panels to cover the door rot? (Stampede or another brand)
Old Feb 14, 2008 | 09:05 PM
98DodgeRam1500's Avatar
98DodgeRam1500
Default ABS Rocker Panels to cover the door rot? (Stampede or another brand)
Anyone ever use Stampede Rocker Panels? I see they come in black ABS. I can't find an image of them in black, the camo image is all over the place. I guess since they are paintable I could paint them. I just would like to know if anyone has used/seen them, I want to know if i can grind off the rust and rust proof the door then cover the mess up with this ABS rocker panel?
here is the camo image...
[IMG]local://upfiles/80976/8F67B33FFA2C4996941491EF0CEA01E6.jpg[/IMG]
Old Feb 14, 2008 | 10:29 PM
98DodgeRam1500
Default RE: ABS Rocker Panels to cover the door rot? (Stampede or another brand)
Trying to avoid getting the diamond plating or the stainless/chrome or the camo.
no one has this?
Old Feb 17, 2008 | 04:17 PM
98DodgeRam1500
bump?
Does using the bedliner on the rockers cover up imperfections?
Old Feb 17, 2008 | 06:02 PM
TheForce55555's Avatar
TheForce55555
Yes it will cover it up, herculiner suggest like 3 coats and thats almost an 1/8 inch thick
Old Feb 17, 2008 | 06:10 PM
aim4squirrels's Avatar
aim4squirrels
ORIGINAL: 98DodgeRam1500
bump?
If you have a relatively flat surface, yes.
Spray on bedliner isn't going to function like Bondo, but it's more forgiving than paint.
