Need posi rear, 9 1/4 or dana 60?
I am trying to convert my truck to a light street racer. I have a 97 1500 pick up with a 5.2 and a 9 1/4 rear open. I need a posi rear because i will be putting in twin turbos. Is there a posi assembly i can buy for the 9 1/4 and would it hold the increase in horsepower? or should i get adana 60? and do those come with a 5 lug hub, i dont want to change rims. some one please help!
RE: Need posi rear, 9 1/4 or dana 60?
While certainly not bullet proof I'm quite sure a Ford 9 inch will endure way more abuse than a 9:25. I would rate the 9:25 better than the 8.8 they put in most ford 1/2 tons but not higher than the 9 inch
Had bad luck with Fords Cereal?
I would hope you would get a substantial power increase with twin turbos. Why such low expectations?
Nah not really. I had a 19902wd ranger I put through all kinds of hell and it held up alright. Exhaust system rotted out. Frame cracked in half. One iac went out on me. One water pump. Ate about 2 quarts of oil per 3000 miles. Ironically the transmission and the rear end held up fine and I use to spin the tires (little tires though) and all kinds of stupid **** all the timein that truck.
Wll, my expectations are low for the twin turbo because I do not want to do any internals on the engine, at least not at this point. So I don't plan on boosting more than 10 pounds, and some local turbo users say that might even be pushing it. And if the 9 1/4 can stand some punishment I'll stick with it, less to swap out, just need to get a posi inside it.
Trending Topics
I'd go with a Auburn LSD or Detroit Trutrac or whatever. I would stay away from the factory trac locks. They don't seem to hold up under stock power so I'd really be cautious using it with a twin turbo setup.
I put a Auburn LSD in my truck to replace my factory LSD that was coming apart.
