Anti-freeze leak
Old Feb 21, 2008 | 12:23 PM
DuranguenzeRam's Avatar
DuranguenzeRam
Default Anti-freeze leak
Rushing out the door i noticed little drop spots of antifreeze lo and behold i crouch down and notice there was a leak. Having replaced the Water pump along with thermostat a few years ago i have discounted also. Also about two years ago replaced the gasket water pump etc. Now before i go nuts where should i look. at first glance saw by the front right side of the truck the drip stains along with some antifreeze. This was the first day i saw it so probably just starting. Any ideas btw its a 2000 5.9 4x4 ext cab
Old Feb 21, 2008 | 02:19 PM
jperkins812's Avatar
jperkins812
Default RE: Anti-freeze leak
I would look up under the truck to see maybe if the leak is coming from the weep hole on the water pump, it could have gone bad. I would also check the hoses, radiator andanything else that is in the cooling system tomake sure that nothing else is leaking also.
Old Feb 21, 2008 | 06:55 PM
bozzoswald's Avatar
bozzoswald
also check your rad petcock
Old Feb 21, 2008 | 09:32 PM
specialist484's Avatar
specialist484
get a bottle of radiator stop leak before you start tearing through the engine
Old Feb 21, 2008 | 09:38 PM
hometheaterman's Avatar
hometheaterman
ORIGINAL: specialist484
Don't put this crap in there. It is a pita to clean out and just a bandaid for your problem. I wouldn't risk putting it in there. Just find the problem and have it fixxed.
Old Feb 21, 2008 | 09:41 PM
SilverRam_01's Avatar
SilverRam_01
Check the front of the motor, it could be leaking from the thermostat neck
Old Feb 21, 2008 | 10:06 PM
bozzoswald's Avatar
bozzoswald
thank you hometheaterman
Old Feb 22, 2008 | 01:57 PM
DuranguenzeRam
Thanks after all this suspicion it is the water pump starting to go, going to replace it and do the plenum while im in there tstat and so on. Thanx for the help, i tried the stop leak on a chevy never would i try on the dodge lol
