B&G PCM
Old Feb 25, 2008 | 09:43 PM
  #21
IndyRamMan's Avatar
IndyRamMan
Default RE: B&G PCM
ok. Im going to run ls1 injectors when i get running again and hopefully that will fix the issue, because its hot all the time. Iv set the idle from 700-3k to see if it was the same throughout, and it remains hot.
Old Feb 25, 2008 | 09:48 PM
  #22
mopowar's Avatar
mopowar
Default RE: B&G PCM
If by setting the idle?? you mean sitting in the driveway, it will always be hot. Which cam did you go with?
Old Feb 25, 2008 | 10:10 PM
  #23
IndyRamMan's Avatar
IndyRamMan
Default RE: B&G PCM
ORIGINAL: mopowar
yea sitting in the driveway.
218 224, 270 276, 513 513, 112 @110
Old Feb 25, 2008 | 10:24 PM
  #24
padodgeram's Avatar
padodgeram
Default RE: B&G PCM
ORIGINAL: IndyRamMan
ORIGINAL: mopowar
geezz cant understand why she runs lean... , mite need to run a #30 injector
Old Feb 25, 2008 | 10:35 PM
  #25
IndyRamMan's Avatar
IndyRamMan
Default RE: B&G PCM
ORIGINAL: padodgeram
ORIGINAL: mopowar
possibly, but I got the ls1s for free, comes out to 24 lbs on stock pressure rating. Since were on the topic....do you guys know of any adjustable fuel pressure regulators I can use? Preferably something that can be run inline btwn the fuel line and the fuel rail.
Old Feb 25, 2008 | 10:58 PM
  #26
CPTAFW163's Avatar
CPTAFW163
Default RE: B&G PCM
I was just about to ask if we can use adjustable fuel pressure regulators. or even can the stock fuel pump and install another Inline electric pump. My buddy ran 70 PSI in his daily driver mustang after his cam install. ANd he was running 24# injectors.
Ind, i am surprised you did a cam swap without changing injectors. Thats like not changing your carb jets after a cam install (like I did) and my350 used to glow like a jack o lantern.
I have 24# injectors and my truck is basically stock. Nothing really warranted it, but the prev owner put them in. all he was running was the Mopar PCM, gutted cat, sidepipesand injectors. I added the headers, MSD and fastman.
She is getting there. I just need to find some female connectors for my crank and cam ps sensors. The wiring harness i bought has these other type of 3 pin connectors on it that don't fit. They were spliced in.
Old Feb 25, 2008 | 11:05 PM
  #27
mopowar's Avatar
mopowar
Default RE: B&G PCM
Our stock systems are returnless.
Old Feb 25, 2008 | 11:06 PM
  #28
IndyRamMan's Avatar
IndyRamMan
Default RE: B&G PCM
ORIGINAL: CPTAFW163
yea, I wasnt sure about how the tune was going to act with what was in there, so I wanted to give it some miles to figgure out what needed to be changed. They were #1 on the watch/change list.
Old Feb 25, 2008 | 11:13 PM
  #29
mopowar's Avatar
mopowar
Default RE: B&G PCM
112 @ 110 - I didn't get that part. 218 int. 224 exh. @ .050 on a 110 or 112? I ran a 218 224 Hughes grind that wasn't worth a fk, but it was on 114* lobe centers.
Old Feb 25, 2008 | 11:28 PM
  #30
IndyRamMan's Avatar
IndyRamMan
Default RE: B&G PCM
112 lsa installed at 110
