changing small things to make a difference
are there any small things that i could change in my truck for added performance? like i know i should change my pcv valve pretty much every time i change my oil. but is there anything else
TPS mod, CPS mod.........both are free just take a littleelbow grease
14 by 3 open element air cleaner........roughly 35$
Cleaning the Throttle body....................priceless..............als o you can check too see if your plenum is blown while cleaning the TB
ORIGINAL: jarebear86
The service manual calls for checking it/replacing as necessary at 30K intervals...
Just wondering why you do that...not a bad thing.
what do yall think about these oil filter magnets????
http://www.stylintrucks.com/parts.as..._prod_ids=1585
Trending Topics
Wide (0.050) gaps on fresh sparksplugs with sharp edges
might be considered small but almost always adds torque
Balancing your eight cylinders
by having a fuel injector either slightly larger
(likely in cylinders 7 and 8)
or slightly smaller injectors (cylinders 1 and 2)
is worth considering
suspension alignment...particularly toe in
can add to performance and fuel economy
every psi you add to air pressure up to the 'optimum' for your driving style
increase fuel economy
ORIGINAL: Ram2K1
Why wouldyou need to do that?
