SOB...a little help (steering stabilizer)
Old Feb 27, 2008 | 06:25 PM
Ram2K1's Avatar
Ram2K1
Default SOB...a little help (steering stabilizer)
So I got my stuff from Jegs and I went out today to put my new steering stabilizer on...couldn't the flippin old one off! I got the bolt out and disconnected the passenger side. Got the nut off of the driver side connection, but it wouldn't come out of the arm that it attaches to... I beat the **** out of it, but it never would budge. Finally I just said f it and put the passenger side back on. I left the nut off of the driver's side in hopes that it will just pop loose... How the heck do you get it to slide out???[:@]
Old Feb 27, 2008 | 06:36 PM
padodgeram's Avatar
padodgeram
Default RE: SOB...a little help (steering stabilizer)
mite need some heat on it , or try a pickle fork , and a BFH ,
Old Feb 27, 2008 | 06:39 PM
Ram2K1's Avatar
Ram2K1
I thought about the heat, but I don't have any source for it. That could be it...it's been pretty cold here. You think a heat gun would do? A guy at work has one of those... If it comes down to it, I'll grind that b*tch off.[&:]
Old Feb 27, 2008 | 07:20 PM
TheForce55555's Avatar
TheForce55555
The heat gun, or one of them propane torches would help out but you will probably still end up beating your brains out
I would suggest grinding anything off because it will still be stuck in there, atleast when its all there you have something to slug on with a hammer
Old Feb 27, 2008 | 09:55 PM
Ramsrush's Avatar
Ramsrush
I had the same problem,used a pipe wrench and it came right out.
Old Feb 27, 2008 | 10:11 PM
Aubrey's Avatar
Aubrey
Same thing with mine. Pickle fork and BFH.
Old Feb 27, 2008 | 10:16 PM
highlander73's Avatar
highlander73
Its a wedge fit on purpose to avoid wobbling. I used a pitman arm puller, but the auto parts store guys also said use a BFH but you need to hold a second hammer against the backside or else the steering linkage just absorbs the blow and does nothing to the bolt.
Just go buy a $15 pitman arm puller or rent one. Worked fine.
Old Feb 27, 2008 | 11:01 PM
Ram2K1's Avatar
Ram2K1
Thanks for the help guys. I'm sure heating it up would help, too. I'll try again tomorrow.
