i want 35in shoes how hi do i need 2 go
Old Mar 2, 2008 | 04:13 PM
dsertdog56's Avatar
dsertdog56
Default RE: i want 35in shoes how hi do i need 2 go
Running a 3 inch spacer with out longer control arms and a track bar mount may send your 305s into your fender wells or control armstoo.
So will rims with too much positive offset. (Scrub radius).
Old Mar 2, 2008 | 04:24 PM
pipeking's Avatar
pipeking
it is sopposed to be a leveling kit of sorts.the 2' spacer has no problem so you why do you think another inch will do that?
Old Mar 2, 2008 | 06:25 PM
97Ram 5.2's Avatar
97Ram 5.2
I just put 315 75 R16 tires on my 97 ram w/ a 3 " lift and there is plenty of room so you can deffinately fit 35's on a dodge w/ a 3 inch lift
Old Mar 2, 2008 | 06:37 PM
erikb45's Avatar
erikb45
why do YOU think that a 2" leveling kit doesnt have problems. it does just like desert dog said
3" spacers just magnifies the problems. save your money and do a full lift kit or use a body lift.
Old Mar 2, 2008 | 08:36 PM
xskylinedx's Avatar
xskylinedx
I've read that a 2" leveling kit on a Ram equiped with the Offroad package will run 35's without any trouble provided you install the proper length control arms. True or False?
Old Mar 2, 2008 | 09:12 PM
toshsibalaptop's Avatar
toshsibalaptop
Junior Member
pipeking
Look at the pics of my 98 1500. It is not really a sport, I just made it look that way. It is an SLT though. Those are 315/75/16 tires. I have a two inch coil spacer on front, thats it. Those are of course stock wheels. I had those on there a year before I put the spacer on. Yes they rubbed but I could live with it. Now they only rub a little when I turn one way (can't remember which). Save your money, put on the tires first then see if you can live with the way they are.
Old Mar 3, 2008 | 08:54 AM
Aubrey's Avatar
Aubrey
305/70/16 Pro Comp All Terrain on stock wheel and no lift no rub.
Incidentally, a Nitto Terra Grappler in the same as above will rub your control arms.
[IMG]local://upfiles/51567/1C6DF4E01CD444F7AB9359C3182AAF6E.jpg[/IMG]
Old Mar 3, 2008 | 08:59 AM
Aubrey's Avatar
Aubrey
35" Interco Trxus MT on 8" wide steel wheel with 3" Skyjacker Stage II system and minor front fender trimming, no rub.
[IMG]local://upfiles/51567/6291B02E49FE4C7EA83EA290CACAAE95.jpg[/IMG]
