U/D Pulleys
Old Feb 28, 2008 | 10:45 AM
engineblock's Avatar
engineblock
Default U/D Pulleys
Does any body know where to purchase the U/D pulleys, i saw some on jegs but they're like 200.00 i need something cheaper?
Old Feb 28, 2008 | 10:46 AM
TheForce55555's Avatar
TheForce55555
Default RE: U/D Pulleys
Summit has a set for 150$ for our trucks
Old Feb 28, 2008 | 12:03 PM
nolazach's Avatar
nolazach
ebay
Old Feb 28, 2008 | 12:59 PM
greenmachine's Avatar
greenmachine
I got mine from ASP which can be purchased through Summit.
Old Feb 28, 2008 | 01:40 PM
nolazach's Avatar
nolazach
greenmachine-- every time I see your sig, I get all green with envy.
That is the best looking hood ever IMHO.
Old Feb 28, 2008 | 02:28 PM
TheForce55555
Did you notice difference when you installed them on your truck, are they worth it??
Im contemplating getting the the set with 3 pulleys, water-pump, alt, and crank
Old Feb 28, 2008 | 03:25 PM
pcfixerpro's Avatar
pcfixerpro
ORIGINAL: TheForce55555
Where did you find the 3 pulley set? I can only find jet performance with two pulleys (alt & Crank) Honestly though... does shrinking the already small alternator pully make that much of a difference? If you find the three pully set, please post! I was planning to do this in conjunction with the HS 1.7's
Old Feb 28, 2008 | 08:46 PM
aim4squirrels's Avatar
aim4squirrels
March makes a 3 pulley set
I think stripper motorsports sells them, but they are listed as Dakota pulleys. I believe they still work. RM_Indy runs them, yuo can PM him I'm sure.
Old Feb 28, 2008 | 10:52 PM
pcfixerpro's Avatar
pcfixerpro
They say they fit up to 97's on stripper motorsports. Thats when they changed the waterpump from presson to bolt on i believe. so... guess that still wont work will it?
Old Feb 28, 2008 | 11:41 PM
CPTAFW163's Avatar
CPTAFW163
All you really need is a different crank pulley. Thats all i would do. Thats where the most drag is. The rest is splitting hairs. Now, if you are doing it for cosmetics, get the 200 dollar march set.
Crank pulley and electric fan is all you need. That will free up 20-30 horses.
