transmition wierd?
You definatly need to look close at the fluid if it is gaining fluid then I will bet you have a coolant leak check you rad also to see if there is any trany fluid in it.
ORIGINAL: jason.w
If your Dodge has the digital readout for mileage below the tachometer/temp gauge, you can get any codes it might have by doing the "key to on" trick.
There is nothing wrong with the Ram but I gave it a go as I hadn't heard of it until reading about it on here.
Anyway,the display read 'P DONE' so for the guys with the 98/99s it might work. Does anybody know the meaning of 'P DONE'???
Thanks.
[sm=icon_cheers.gif]
Just got the code it was P0740 Torque convirter clutch no RPM Drop at lock up. What does this mean? How do you tell if torque converter is bad? After draining out some fluid I took the truck for a drive and I lost everything. I mean park,drive, second, and first. I shut it off and restarted and It was working again, but would not shift out of first by itself. Moving the shifter sometimes it would shift and sometimes not.
PLEASE HELP IF YOU CAN!!!!!
Also forgot to say that before I lost everything the truck died like it ran out of gas, but started right back up. Could my computer be bad? Is there a seprate computer for the tranny? THANKS!!!!!
ORIGINAL: dodge@1997
Ok I checked the fluid hot ideling and in neutral and it showed over full. I just checked it with the engine shut off and Ii shows the same reading it did ideling in nutral. Pump???
