Derale 14110 Transmission Pan with cooling
Old 03-02-2008, 11:41 AM
98DodgeRam1500's Avatar
98DodgeRam1500
98DodgeRam1500 is offline
Default Derale 14110 Transmission Pan with cooling
I was flipping through my Summit catalog and found Derale Transmission pans.
model 14110 is for the 518 and adds 3 more qts and a drain plug.
Just wondering if anyone here is using it.... its only $81.95.
http://www.derale.com/pans.html
I might pick up one of these when I get the tranny oil/filter changed.
Old 03-02-2008, 06:51 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
Default RE: Derale 14110 Transmission Pan with cooling
i saw those. it looks like there's a lot of things that could go wrong. mud, rust, leaks, etc.
i think a cooler would do a better job of cooling.
and i think this hughes pan would be a better option on extra capacity. i think i'll get one of these later this year. the kit includes a filter.
http://www.jsrautospecialties.com/se...on-pan,/Detail
Old 03-02-2008, 07:32 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
Good find vaughan! I'd suggest a non-cork gasket. I ran one of those cork rubber gaskets and couldn't get it to seal properly, I think they're too flat. The rubber seals have more thickness to them.
Old 03-02-2008, 09:13 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Jr. Mechanic is offline
ORIGINAL: 98DodgeRam1500
Unless I am missing something, they do not have one listed for the 46RE.
Old 03-02-2008, 10:57 PM
98DodgeRam1500
ORIGINAL: Jr. Mechanic
I am no transmission expert, but I know that...
A518 is the same as46RH &46RE. Found that out when I was doing research on getting my "518" rebuilt.
Google "dodgetransmission 518"
http://www.google.com/search?q=Dodge...mp;startPage=1
Also read that you can use a 727 pan/gasket in the 518, think I read that in this forum. People were doing that to gain more capacity and a drain plug.
Edit:
just did a forum search on the 727. Its not a larger capacity....
Old 03-02-2008, 11:05 PM
98DodgeRam1500
dhvaughan,
Were you the person who installed the B&G Transmission Filter?
hows that working out?
I want to get the perma-cool deluxe. So I can get both functions of it filtering and housing the sending unit for my transmission temp gauge.
I am just leary of it affecting line pressure and restricting flow...
how long have you had it?
do you tow anything?
Old 03-03-2008, 02:37 AM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Dodge Forum Moderator
Correct. Found the same info when I was looking for someone on another thread.
This will also tell you the same thing...
http://www.dreviltransmissions.com/46RE.htm
Old 03-03-2008, 07:23 AM
dhvaughan's Avatar
dhvaughan
dhvaughan,
it was me.. https://dodgeforum.com/m_717634/tm.htm
works good.
i've had it about a year.
i don't have a temp gauge, so i can't really say how much good its doing, but i figure its doing something and it might extend the life of the transmission.
i tow a boat occassionally, not much. a friends tractor a couple times a year. haul a lot of wood.
the remote filter is handy. given all the hundreds (or thousands) of posts here about transmissions, i try to change the fluid every year. this past year i used the drain plug in the pan and replaced the remote filter and called it done. this coming year i think i'll get the Hughes pan and change the internal filter.
Old 03-04-2008, 06:26 PM
Jr. Mechanic
Edit:
Wow, you learn something new everyday I guess. **Opens mouth, inserts foot***
Old 03-04-2008, 07:45 PM
98DodgeRam1500
Thats what this forum is all about. Trading knowledge.
Quick Reply: Derale 14110 Transmission Pan with cooling
