Engine ground straps melting, help?
Old Mar 5, 2008 | 08:29 PM
IndyRamMan's Avatar
IndyRamMan
Default Engine ground straps melting, help?
I have no freekin clue why my ground straps keep melting. I did it once before, but that was only because I hooked up the battery to the head rather than to the alternator. I fixed that (this was a couple months ago) and didnt have an issue. The fire melted the wires, so I replaced them. Every time I go to start they start smoking and get hot. Any ideas?
Old Mar 5, 2008 | 08:30 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Default RE: Engine ground straps melting, help?
Usually if that happens there is either a bad connection, or maybe the fire did something to your starter causing it to draw more power than is usually required, or something is shorting out when you turn the key, melting the ground straps.
Old Mar 5, 2008 | 08:40 PM
IndyRamMan's Avatar
IndyRamMan
theres nothing thats not replaced in the engine that is electrical that was damaged
Old Mar 5, 2008 | 08:45 PM
wvjefo's Avatar
wvjefo
Indy
You have a short. Sorry, you may need to check the entire electrical.
Start at the engine first. It is the major power. check the wires for wear, check all the connections. Take your time
Jeff
Just an old guy with a car hobby
Old Mar 5, 2008 | 09:01 PM
IndyRamMan's Avatar
IndyRamMan
I know theres a short some place...but what is involved in the engine circut. What systems are grounded through the motor grounding straps?
Old Mar 5, 2008 | 09:16 PM
pipeking's Avatar
pipeking
yeah you deffinatly nead to follow the wires that are involved in the starting.
Old Mar 5, 2008 | 09:20 PM
pipeking's Avatar
pipeking
if everything got replaced after the fire,maybe at the relay, after sending power out to load ,you also have power going to the ground ,instead of where its saposed to go.just fallow the wires.
Old Mar 5, 2008 | 09:22 PM
Jr. Mechanic
Well I would check all of your wires for the alternator and for the starter to make sure nothing is touching on the block, and did you replace your alternator? Something may be shorting out in there...
Old Mar 5, 2008 | 09:54 PM
pcfixerpro's Avatar
pcfixerpro
Im sorry, but the only solution I see is to give me your motor so I can put it in my truck... jk... good luck figuring it out tho.
Old Mar 5, 2008 | 11:44 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Jr. Mechanic
didnt replace the alternator, it looked like it was good, I may have to go get it tested to be sure.
Does anyone know if the bracing that goes btwn the block and the trans (oil pan to bellhousing) is part of a circut. I chose not to put them back on.
