Q's for Timing chain, Water pump and rear main seal replacement.
Old Mar 9, 2008 | 08:44 PM
  #21
highlander73's Avatar
highlander73
Default RE: Q's for Timing chain, Water pump and rear main seal replacement.
ORIGINAL: Jr. Mechanic
Yep. I always use it on WP bolts, after doing a WP on a 91 (?) bronco II. Like 3 of the 4 bolts sheared off into the timing cover, thus turning it into a timing job. So long as you torque the bolts correctly, they wont come out from normal vibrations, the anti seize just protects against the bolts getting corroded or rusted in.
+1
Using anti-seize on any parts that could rust or you want to take out again at some point in the future is a wise idea. The package for the anti-seize I have says : spark plugs, water pump bolts, starter bolts, etc.
