really dumb question
Old Dec 27, 2004 | 04:07 PM
banwhalen's Avatar
banwhalen
Default really dumb question
anyone know the wrench/socket size I need to use on the belt tensioner to remove the serpentine belt on a 98 360 cid? Before I strip the thing, I need to know if it's metric or sae. As I am hearing that the engines are using metric. But for some reason, my sae have worked on the valve cover bolts and the oil drain plug. I cannot remember what I used in the past, I know it was sae, but it looks like it wasn't the right one from the looks of the bolt now.
I actually stopped the process to post this question so as not to f#*k up the bolt as I am wising up in my old age.
thanks for any info
Old Dec 27, 2004 | 04:51 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: really dumb question
i am not sure on the size, but i would use metric if i were you...smaller increments...
Old Dec 27, 2004 | 08:02 PM
moparturd's Avatar
moparturd
Is the tensioner spring loaded, in which case you just swing it out of the way to remove the belt.
Old Dec 29, 2004 | 02:38 AM
SnipeRT's Avatar
SnipeRT
I'm not sure of the size, but I KNOW it is metric. So use the metric wrench that fits. It is one of the only pieces under your hood that requires a metric wrench.
Todd: I don't think he is planning on removing the tensioner. He was just asking for which size wrench to use for leverage so he COULD swing the tensioner away from the belt.
Old Jan 13, 2005 | 09:23 PM
hunterrd's Avatar
hunterrd
hey man it is a 15mm wrench. be carefull if it won't move you are going the wrong way, That is mad of pot metal it will break. Good luck
Old Jan 15, 2005 | 04:21 PM
Blylock's Avatar
Blylock
ORIGINAL: banwhalen
thanks for any info
remember there are similar sae and metric sizes. i believe 12mm and 1/2 are similar, 8mm and 5/16 are similar. im sure there are others, but im not a pro
Old Jan 16, 2005 | 01:50 PM
steve05ram360's Avatar
steve05ram360
ORIGINAL: hunterrd
It is 15 mm, and you can only go one way... if your going the wrong way, take it to a shop
