has anybody mod tps
RE: has anybody mod tps
I'm not sure of the techincalities of how the mod works but I can check my TPS at any given moment and it will read about .72, which is where I set it. I have to believe this is thereference(?) or at idlevoltage.
But it will not turn your ram into a tire smoking monster truck. Not even close. You my "feel" the motor is a bit snappier, but not one more inch of rubber will you burn, nor a drop less of gas.
Stock mine was .56volts and anything over .72volts tripped a cel.
Track testing stock voltage and .70 made no difference at all regardless of adaptive learning or reseting the pcm prior to a pass.
It was as usefull as the iat mod (no difference relocating iat either)
