Hmm... Injector cleaning.
Old Mar 15, 2008 | 04:35 AM
Slomojo's Avatar
Slomojo
Default Hmm... Injector cleaning.
How could one go about cleaning a set of injectors without paying an arm and a leg or just putting something into the tank?
Anyone ever pull them out and hand clean them in a solution or anything like that? A while back my dad's van had injector issues and the dealer did something to clear it up on the spot but it wasn't just something in the tank... I don't have a clue what they did but it worked great. Anybody have a clue what to do?
Old Mar 15, 2008 | 02:32 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Hmm... Injector cleaning.
I clean them with an ultrasonic bath I bought from Walmart online. $35.00 and I can clean my watch with it too. It works fantastic and I just used a bottle of Chevron Techron as the solution.
This isn't the one that I bought but looks like an upgrade:
http://www.walmart.com/catalog/produ...uct_id=8130170
I actually bought the other Haier model.
Old Mar 15, 2008 | 02:56 PM
Tarner's Avatar
Tarner
I have that same ultra sonic cleaner. The thing works great. The only thing I didn't like about it is how long the time can be set for. the longest time setting it has is 480 seconds or 8 minutes. Other than that it works great!!!!
Old Mar 15, 2008 | 03:01 PM
highlander73's Avatar
highlander73
I bought this one (was on sale for $19.99) and use mineral spirits as the cleaning agent. I don't know if it was this cleaning or the plenum repair i did at the same time, but my truck idles real smooth now.
Old Mar 15, 2008 | 07:34 PM
motorbrreath's Avatar
motorbrreath
+1. wal mart sells that sonic bath, pull the rail, pull the injectors, make sure you buy new o rings (there are 2 on each injector). i did mine in a bath of sea foam.
Old Mar 15, 2008 | 08:37 PM
pipeking's Avatar
pipeking
ok wait this is the 2nd time ive herd this.when i did my plenum last week i bought new o ring for the injectors,but the part store only had 2 paks in stock (4 pr pak)so i only had 8 o rings so i figured on only replaceing 1 on each injector.so when i pulled the injectors i only had 1 o ring on each,and only 1 spot.so now somthing seems fishy,any answers?
Old Mar 15, 2008 | 08:39 PM
aim4squirrels
There is one o ring at the top and bottom of each injector. One seals the fuel rail, one seals the combustion chamber for each cylinder.
Old Mar 15, 2008 | 08:44 PM
pipeking's Avatar
pipeking
oh, da i should have known that,ive had a long day.thank am4sqlz.
Old Mar 16, 2008 | 08:22 AM
Slomojo's Avatar
Slomojo
Looks like I'll be looking into the sonic baths. I had no idea those things were that cheap. Thanks for the advice everyone, much obliged.
Old Mar 16, 2008 | 03:48 PM
motorbrreath
just make sure to apply some fresh oil, or petrolium jelly to those o rings when reinstallin em. it took me forever to get them back in, and when i would, one would leak. Finally after the 4th time of pullin the rail and reinstalling it i got it leak free. Also, stay away from the stealership (naturally) for those o rings. They wanted $15 for 2. Advance sells felpro's that are $3 for 4. So your gonna need 16 o rings to get the job done right.
