Best Headliner Solution
Old Mar 21, 2008 | 02:05 PM
8t5gt's Avatar
8t5gt
Default RE: Best Headliner Solution
hey guys, if your into diy, i made my own for my 85 mustang t top. i went to the local fabricland got a nice thick fleecy type material then scrapped the old crap off(left the foam on) then sprayed a tonnnnnn of glue onto the cardboard and smoothed it out. it worked amazing, i love touching it now lol!
it onlycost about30-35 bucks tops for glue andfabric
Old Mar 21, 2008 | 02:29 PM
1BigRamaniac's Avatar
1BigRamaniac
I took out two headliners Caravan and Dakota, and let the pro redo it for about 135 and 60 respectively. Then I installed them. BUT you are supposed to do in in July so you can sweat like a pig. They basically wanted around 400 for the job and I was too cheap to do it.
Old Mar 21, 2008 | 05:31 PM
kitchenrat1's Avatar
kitchenrat1
I just did that this fall. Took down the old headliner, peeled off the old fabric (leaving on the foam) then glued on new felt in a matching color. I used the 3m super trim adhesive. It looks great. The secret is to use lots of the spray glue in layers that alternate in direction. Also make sure to let the glue get tacky before the next layer. When you finally have enough layers then roll your new felt into a wide roll. Roll the fabric over the contours of the headliner and smooth it out as you go. When your done fold the extra fabric over the back of the headliner and glue and duct tape it down. Cost- $6 for fabric, $6 for glue and 1 hour work plus 2 hours drying time.
Old Mar 21, 2008 | 07:20 PM
Ramsrush's Avatar
Ramsrush
Yes, with the kit above.
