A few questions, 1 is really dumb
Old Dec 29, 2004 | 11:34 PM
rdream13's Avatar
rdream13
Default A few questions, 1 is really dumb
Hey everyone. I just got a 97 Ram 1500 a few days ago, and I love it! I finally had enough with the damn compact cars.
I read threw some post and realized I have to check into my engines temp, (it runs about 180*)and it is hard to get to the thermostat, exactly how hard is it?
Now for the really dumb question. Today was the first time I put my arm rest up, and for the life of me I cant seem to get it back down!!! Is there a plastic clip or something I am missing? or what ??
Old Dec 29, 2004 | 11:38 PM
moparmania's Avatar
moparmania
Default RE: A few questions, 1 is really dumb
as for the arm resrt mine just goes up and down.lol. the themostat is easy to get at . follow the big *** hose from the top of you radiator to the engine block that is where you will find the themostat . i have a 97 5.2 as well
Old Dec 29, 2004 | 11:44 PM
RcBandit28's Avatar
RcBandit28
ORIGINAL: rdream13
Getting to the t-stat is not overly difficult if you have a basic knowledge of cars. On the Ram, to make it easier you need to remove the A/C compressor and Alternator, which means you also have to remove the belt. Then remove the bracket that holds all that in place. It is not difficult, most all the bolts are the same size. Yon don't have to disconnect the wires to the alternator, just move the alternator out of the way, same with the A/C Compressor, you don't have to suck the Freon out of the system, the lines will bend enough to let is sit on the pass. side inner fender.
Not that dumb of a question, my 97 Ram's armrest does the same thing from time to time. I've found that being gentler w/it will get it back down easier. Also, make sure the vehicle isn't moving when you do this. But as far as any clips or anything, there isn't any that hold it upright.
Good luck w/the new Ram, I love my 97 thats why I still own it, i'll never get rid of it.
Old Dec 29, 2004 | 11:55 PM
LoNeWuLf's Avatar
LoNeWuLf
The only dumb question is the one that goes unasked.
Old Dec 30, 2004 | 03:36 AM
dodgeballz's Avatar
dodgeballz
Thermo is not a bad job at all...but the most valuable tool in a shop is a well stocked library...when you go to the parts store pick yourself up a CHILTON manual...$15-20 and it is indespensable!! I got one with the truck when I bought it and burried it under the seat untill I did my first major repair job...WOW!!
As far as the console goes, just jiggle it back and forth it'll come down eventually...I think they all do that after a while.
You're gunna love the truck!!
--Dylan
Old Jan 8, 2005 | 01:46 AM
rambo97's Avatar
rambo97
my 97 does the same thing with the console! LOL... I have found for some reason it does it more when it is cold outside... also, I tihnk it does it when you put the brakes on... do if you are tryin to put it down while you have ur foot on the brake... that could be it...
Old Jan 10, 2005 | 10:12 AM
banwhalen's Avatar
banwhalen
Not dumb.
I have a 98 Ram w/manual seats and the drivers seat is stuck. I cannot adjust the seat back. I am the only driver and apparently the damned metal/release has fused together over the years. The plastic realease handle stripped when I tried to adjust the seat.
Moral of the story: move the seats around once in a while.
No one else in the entire frickin world of Dodge ownership has this problem. That's the kind of problems I have had with my Ram. I guess the Mexicans who built the pos did it on purpose to get back at americans.
Old Jan 10, 2005 | 03:44 PM
steve05ram360's Avatar
steve05ram360
Leave the t-stat alone unless you think it's not working right. 180* is what is preferred.
Old Jan 10, 2005 | 04:23 PM
purdueranger's Avatar
purdueranger
Take the alternator and A/C compressor off is not needed. I took my t-stat off of my 318 with just an extenstion and a universal. It took me maybe 10 mins from tear down to installing a new t-stat.
Old Jan 10, 2005 | 07:23 PM
steve05ram360
you must not have the "Front" tab on your t-stat housing, it's a bitch to get off with that tab there. grind it off when you have it out.
