Will someone tell me if these Wheels & Tires Will Fit on my RAM?
Old Mar 27, 2008 | 08:38 PM
hometheaterman's Avatar
hometheaterman
Default RE: Will someone tell me if these Wheels & Tires Will Fit on my RAM?
Do you not have any lift at all? I run a 305 on a 16x10 rim with a 3" lift and they rub when I hit a bump at full lock. Not bad enough to worry about but with 10" wide wheels it seems to make 12.5" tires rub I can't even imagine a 15.50" wide one especially if you have no lift. You better make sure that wheel has a low backspacing or else like said they will rub on the control arms. Even then they will probably run on the fenders unless you lift it a fair amount.
Old Mar 27, 2008 | 09:02 PM
wick001's Avatar
wick001
Ok, thanks man... Itlooks to me like they won't fit... To bad because its a hell of a deal.
Old Mar 27, 2008 | 09:11 PM
hometheaterman
The rims would more than likely work if you got tire for them. Is it a good enough deal to do that?
Old Mar 27, 2008 | 09:35 PM
wick001's Avatar
wick001
I know the wheels will fit, but i don't think he wants to separate them...
Looks like i'll be buying 285/75/16's for my stock wheels...
Old Mar 27, 2008 | 11:01 PM
rabbler's Avatar
rabbler
They will probably rub, but you cold adjust the steering stops so they don't
