Will someone tell me if these Wheels & Tires Will Fit on my RAM?
Old Mar 27, 2008 | 03:44 PM
wick001's Avatar
wick001
Default Will someone tell me if these Wheels & Tires Will Fit on my RAM?
I have a 2000 Dodge Ram 1500 Sport 4x4 Single Cab,
The Packageis:
4- 18x10 Polished MICKEY THOMPSON Classic Locks 5 lug (5x5 1/2) Five on Five and a half!!!
4- 375/50/18 but are equal to 33x15.50x18.. MICKEY THOMPSON MTZ's
Will thesefit right on no problems?
Old Mar 27, 2008 | 03:47 PM
hilliad's Avatar
hilliad
Default RE: Will someone tell me if these Wheels & Tires Will Fit on my RAM?
Should fit, no problem
Old Mar 27, 2008 | 03:52 PM
Silver_Dodge's Avatar
Silver_Dodge
I think a 375 might rub the control arms because they are so wide. I'm not sure though.
Old Mar 27, 2008 | 03:54 PM
wick001's Avatar
wick001
These wheels will bolt right up though? What does 5x5 1/2 mean?
Also what year ram wheels will fit on ours?
Old Mar 27, 2008 | 04:00 PM
hilliad's Avatar
hilliad
I thought he said they were equal to a 33". I used to run BFG 315s (almost a 35") and they fit fine with very little rubbing when the front wheel was turned all the way. A 375 would be like a 37". Dont think that would fit without about a 5" susp lift
Old Mar 27, 2008 | 04:08 PM
Silver_Dodge
375 is the width. 33" is the diameter. Since the aspect ratio on those 375's is only 50, they are about 33" tall. I still think they will be too wide.
The rims should be fine. The 5x5.5 is the bolt pattern, and that matches our trucks.
Old Mar 27, 2008 | 04:32 PM
my1500.net's Avatar
my1500.net
Yes they will rub as I am almost sure that the back spacing on a 10" inch wide rim is not going to be 4" inches, more like 5"+ inches which will put it even closer to the control arms.
Old Mar 27, 2008 | 05:36 PM
wick001's Avatar
wick001
I need to know for sure if they will rub because i'm buying them off of a guy tonight...
Old Mar 27, 2008 | 05:42 PM
Tarner's Avatar
Tarner
Are you buying these off the internet? Can you test fit the rims and tires before you buy them?
Old Mar 27, 2008 | 06:04 PM
wick001's Avatar
wick001
i'm buying them off a guy on craigslist, i suppose we could make arrangments to test fit them, but I would rather just know if they will fit ya know?
