rpms
Old Mar 30, 2008 | 01:57 PM
peewee's Avatar
peewee
Default rpms
i have a 97 ram SS/t with a four speed automatic and at 65 mph it runs about 2100 RPM is that right. it seems kinda high for a V8. thank u much for your help.
Old Mar 30, 2008 | 02:40 PM
RM_Indy's Avatar
RM_Indy
Default RE: rpms
Right where it should be
I turn 2200rpms at 70mph with stock dia tires & 392grs
Old Apr 1, 2008 | 06:20 PM
peewee's Avatar
peewee
Default RE: rpms
alrighty think u for your help
[IMG]local://upfiles/87183/29152C9EFC7E4D59B8E4D3047D85F9EC.jpg[/IMG]
Old Apr 2, 2008 | 10:27 PM
98DodgeRam1500's Avatar
98DodgeRam1500
Default RE: rpms
I thought about your post on my way in to work today.
at 65MPH I am roughly at 1600 RPMS.
I took a picture, but I had some serious sun glare, but you can see I am doing about 65-67mph and its at 1600rpms roughly.
I am in a stock 1500 QuadCab with 265/75/16 and 3.55 rear ratio. I also know my speedo is accurate because of the radar trailers they put on the side of the road. they had one on my route to work in 3 different places last week.
I will take a better picture tomorrow AM when the sun isn't so high.
So... I am guessing if you have 3:92 or 4:10s you might be revving higher.
[IMG]local://upfiles/80976/6A51A4C16CAD41C9B6017ED439DBC501.jpg[/IMG]
Old Apr 2, 2008 | 10:37 PM
SarcasticDwarf's Avatar
SarcasticDwarf
Default RE: rpms
Has anyone ever put together a reference chart for normal RPM ranges under different conditions?
Old Apr 2, 2008 | 10:40 PM
TheForce55555's Avatar
TheForce55555
Default RE: rpms
I would say your running about right where a truck should run........ill trade you gears, 3.55's suck unless you have 28" tires
Old Apr 29, 2008 | 08:45 PM
peewee's Avatar
peewee
Default RE: rpms
ok does your truck have a 360?
Old Apr 29, 2008 | 08:50 PM
98cherryram's Avatar
98cherryram
Default RE: rpms
I have a 318, but its a manual transmission, but at 65 I run about 1600 to 1800 rpms in 5th gear, so i dont know, for an automatic that might not be to far off
