Is there no end to the madness?
Old Apr 1, 2008 | 12:51 AM
  #21
nater_660's Avatar
nater_660
Default RE: Is there no end to the madness?
ORIGINAL: granpa49
but I will think twice before buying another Dodge truck.
Lol good well then i guess that leaves more dodge trucks for the people who love them, not trying to be negative but people that dont have problems with their truck arent gonna post everyday that their truck ran great(otherwise there would be millions of posts lol), thats what these forums are for tohelp with problems so thats why your gonna see problems posted about these trucks. Im glad to see your getting help with you truck, best of luck to you, the v6 is a good engine so i hope you get it figured out.
Old Apr 1, 2008 | 01:42 AM
  #22
Chopper1's Avatar
Chopper1
Well this is the second gen. section. Most are 10 years or more old. Things wear out, get beat up, get corroded, rust, fall off, etc. Than if the maintenance was only done whenit brokefor whatever reason than it happens sooner. Stuff happens!!! Other vehicles have issues too.
Old Apr 1, 2008 | 01:55 AM
  #23
Chopper1's Avatar
Chopper1
You must have gone to Chesterfield now PearsonDodge on Midlothian. The last time I went there they replace the steering box and aligned the front end. A few days later my stepson was following me a thought my right front tire was leaning. Got home and jacked it up and noticed the wheel bearing loose/bad. Called them up to see how they aligned itlike that. Their response was that they don't raise the wheels off the ground to do an alignment. They drive on the rack and just shake the tires to check steering joints.They are supposed to be the certified mechanics????? Idiots.....
Old Apr 1, 2008 | 08:36 AM
  #24
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: 1BigRamaniac
Here is Logic 101:
1. Mechanical devices break down.
Ask anyone who owns an older British car (Lucas electrics) or anything Italian (Fiat) and they will attest to that statement!
Old Apr 1, 2008 | 12:34 PM
  #25
granpa49's Avatar
granpa49
RM_Indy I think you are right. I wiggled the clips, removed them and reattached them, and although I could not detect any change in the idle the truck drove better than it has in months. I think only one cylinder was coughing in the test drive. I am going to try and find a set of those clips ASAP.
Old Apr 1, 2008 | 02:15 PM
  #26
RM_Indy's Avatar
RM_Indy
Should drop about 50rpms at idle if you wiggle the injector clip n loose connection.
If its the wires loose/broken going into the clip you need an injector test light to figure out the bad ones. If any show intermittant strobing of the injectors (test light) or if the connectors are bad (even one) I would change all of them. For $15 its less than an oil change (I run synth )
Fingers are crossed for you granpa49
Old Apr 1, 2008 | 05:31 PM
  #27
KevinFoshee's Avatar
KevinFoshee
I have over 200,000 miles on my 97 dodge ram. It runs fine. Just for the record.
Old Apr 1, 2008 | 05:47 PM
  #28
tj1320's Avatar
tj1320
ORIGINAL: VWandDodge
The "pros" don't always know or don't care. FWIW, my truck runs as smooth as silk.
Ditto. Its fixing to run even smoother once I get the stock cap, rotor, and plug wires changed. I'm not sure how many miles the plugs have on them but the other things have just over 107,500 miles on them.
Old Apr 1, 2008 | 10:30 PM
  #29
aim4squirrels's Avatar
aim4squirrels
ORIGINAL: RM_Indy
Quick search on Summit and the only one that came up were these. Number sounds familiar
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD%2D2400&am p;N=700+115&autoview=sku
RM_Indy,
Thank you, thank you, thank you for posting this up. I broke about 3 of those little red retainers when I pulled the intake 6 months ago; they just crumbled in my hand they were so brittle. I ordered them immediately.
Just a question as it's hard to tell from the pics...are these a replacement connector, or an anchor housing that holds the existing connectors together? Do you just cut and splice in the new connectors on the wire looms?
Old Apr 2, 2008 | 01:01 AM
  #30
jasonw's Avatar
jasonw
Site Moderator
My grandfather has a Dodge ram with the diesel, just a year or two before they changed the body style to our 2nd gens. It has over 350,000 miles and is still chuggin away, runs really well with no problems. The only major repairs that he has had done to it, I believe, is a couple things with the air conditioning.
