tow hooks
Old Apr 6, 2008 | 06:50 PM
  #21
Mayfair's Avatar
Mayfair
Default RE: tow hooks
The holes are actually on your air dam, they're just not cut through. Next time you are under your truck, look at the air dam from the inside. You'll see the outline for the holes. Just cut it out with a razor blade and you're good to go.
Old Apr 8, 2008 | 07:36 PM
  #22
doug15's Avatar
doug15
I just went to the salvage yard today and seen aset of tow hooks and the brackets. I got the whole set for 20 dollars. I came with everything; both brackets for each side, both hooks, and the bolts.
Old Apr 9, 2008 | 12:26 AM
  #23
Mayfair's Avatar
Mayfair
DAAAAAAAAAAAAAMN !!! [:-]
You didn't happen to see another set did ya?
Old Apr 9, 2008 | 01:50 AM
  #24
doug15's Avatar
doug15
No,it is rare to find anything that is salvageable on a dodge ram 94-01 around here at our salvage yards. There are like 3 trucks like ours at our salvage yards and i happen to spot out those tow hooks.So I grabbed them.
Old Apr 9, 2008 | 01:00 PM
  #25
GOD RAM IT's Avatar
GOD RAM IT
ORIGINAL: Mayfair
I wonder if they could be pounded or pressed flat and then re-powdercoated?
if you could than they arent worth their weight in manure
