Tranny Advice
Old Apr 2, 2008 | 09:23 PM
MonteC's Avatar
MonteC
Default RE: Tranny Advice
sounds like a plan. Good luck!
Old Apr 3, 2008 | 07:13 AM
turkeyhunter1962's Avatar
turkeyhunter1962
ORIGINAL: 2 Marks
Thanks for the advice.
I think this is what I am going to do. I think I will skip the two options.
PURE EVIL Package Price: $1995
Bushing Kit, Master Overhaul Kit, New OEM Style Filter, New Washers And Bearings, New Bolt In Style Low Roller Clutch, Raybestos Indy Red Clutches In The Forward, High – Reverse, High Energy Overdrive Clutches, Reprogrammed Street Strip Valve Body, New OEM Solenoid, Upgraded 2nd Brake Band To High Energy Material, Upgraded 2nd Band Lever 5.0 Ratio And Band Strut.
Plus Other Upgrades That Dr. Evil Will Not Divulge
Options:
[ul][*]Blue Plate Upgrade: $300[*]Aluminum Deep Pan: $160 [/ul]
http://www.dreviltransmissions.com/home.html
That's the tranny that I have in my truck right now, but I did go with the deep pan. If you can afford it, get it. Very much worth having. In addition to holding the extra fluid, it helps cool the fluid and has a drain plug for changing fluid. I tow a 9000 lb fifth wheel with my truck and have had the tranny in the truck for almost a year. Very happy with it and I believe Billy "aka Dr. Evil" is the most knowledgable person that I have ever talked to about trannies.
