SUPERCHARGER!!!!
Old Apr 10, 2008 | 01:29 AM
Lotusttu84's Avatar
Lotusttu84
Default SUPERCHARGER!!!!
Hey guys. I got the 97 dodge ram ss/t with the 5.9L 360 V-8.
I just got a Supercharger for it. It came with a smaller pully for 12psi!
What should I exspect from this when i install it?
What kind of power?
Shawn
Old Apr 10, 2008 | 01:55 AM
rabbler's Avatar
rabbler
Default RE: SUPERCHARGER!!!!
I think 12 PSI is way to much to just bolt on the stock engine.
What other mods are you planning for this engine?
Old Apr 10, 2008 | 02:24 AM
Lotusttu84's Avatar
Lotusttu84
well i have headers, high flow cat, and muffler. I also have the stock pully for the charger that runs the charger at 8-9psi. If it blew the motor I would be pissed but I would also be excited to build a new one with better parts!
I want to put on a new throtle body and redo the heads.
Old Apr 10, 2008 | 02:32 AM
Wrestling4x4's Avatar
Wrestling4x4
what about the innerds? injectors? ur gunna need all that running that much psi..
Old Apr 10, 2008 | 02:42 AM
Lotusttu84's Avatar
Lotusttu84
Thats what I was thinking Wrestling4x4. What wold you guys say would be the best to get the most out of my motor with a supercharger?
Old Apr 10, 2008 | 03:15 AM
jasonw's Avatar
jasonw
Site Moderator
ORIGINAL: Lotusttu84
I want to put on a new throttle body and redo the heads.
For the TB, go with the Fastman.
That's my two cents.
Old Apr 10, 2008 | 03:24 AM
motorbrreath's Avatar
motorbrreath
alot of work. head work, bigger injectors etc. puttin that on a stock engine with no upgrades is gonna cause some problems.
Old Apr 10, 2008 | 07:18 AM
JBs DAK's Avatar
JBs DAK
At 12 lbs your gonna go lean. Eat head-gaskets.
Retard the hell out of the timing, it might hold for a week. Be ready
to start a head-gasket collection.
You want to up-grade your fuel-pump, get a adj.-fuel reg, bigger injectors,
cooler thermostat, and keep the motor nice and cool before tromping on it.
(Mabe a high-flowing elc-fan). Good luck,.. See ya at the parts store.
Old Apr 10, 2008 | 09:27 AM
IndyRamMan's Avatar
IndyRamMan
you should expect a broken bottom end...
Old Apr 10, 2008 | 10:04 AM
Boardingkaos's Avatar
Boardingkaos
I suggest forged pistons and rods and least. get larger injectors along with a bigger fuel pump and do some head work. like JBs said, retard the timing a lot and be sure to tune it before you drive the hell out of it or youll loose a lot of your money to hear some interesting sounds of your engine breaking.
start with the 8psi pulley, its not worth it to dive into that much psi just because youre excited. take it slow and do everything right and youll be even happier when youre done with it!
Good luck!
-Chris
