tranny cooler questions?
Old Apr 10, 2008 | 08:27 PM
mstephen89's Avatar
mstephen89
Default RE: tranny cooler questions?
ok, so even though it is thinner you think that it is a better cooler
Old Apr 10, 2008 | 09:16 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: Jr. Mechanic
BIGGER IS NOT BETTER!! (At least when it comes to this) It is just as bad for you transmission to be operating too cool as it is for it to be operating too hot. This is the one I recommend: http://www.jegs.com/p/TCI/748659/10002/-1/10535
+1.ForFlorida it should be fine though.
remember, your water temp is also "showing" you your trans temp. The trans temp is diffrent than the water temp, but if your running the stock cooler (which is in the radiator) what happens to the temp of the water happens to the temp of the trans. Overhead the water, sometimes youll overheat the trans.
Old Apr 10, 2008 | 11:09 PM
rabbler's Avatar
rabbler
I 'think' the 8 rows would be better than the 6. I think tube size is the same for both. Even though the 6 rowhas thicker fins I think the extra 2 rows would more than make up for the reduced fin area. Both are probably overkill for anything your truck could tow anyway.It's hard to compare as neither rates BTU or weight capacity for the coolers.
If your concerned about over cooling run the hot pressure line from the trans to the New cooler then through the radiator and back to the trans. Most factory systems are plumbed this way so that the engine coolant can warm the trans fluid if it gets too cold.
I don't think it's as important as you areso far South but it still good insurance. It's definitely the way to go if you get any kind of winter weather.
Old Apr 10, 2008 | 11:32 PM
hometheaterman's Avatar
hometheaterman
I like my B&M I got from Jegs. I'd recommend it.
Old Apr 11, 2008 | 12:02 AM
Mudbone25's Avatar
Mudbone25
The Flex a lite on is 26,000 gvw according to their site. Not sure about the summit one.
Old Apr 11, 2008 | 12:22 AM
Wickedwiggles's Avatar
Wickedwiggles
I got the flex and love it.
Old Apr 11, 2008 | 08:28 AM
mstephen89's Avatar
mstephen89
you have the flex a lite that we are talking about. Was it an easy install and did it fit well, also what all did it come with. BTW I regularly tow around 6-7000lbs, and this summer I will probably tow more.
Old Apr 11, 2008 | 09:33 AM
ap0x's Avatar
ap0x
Might I suggest something like this...
http://store.summitracing.com/partde...p;autoview=sku
or depending upon your truck, something a little bigger...
I pull nothing less then 10k, more on a regular basis. Plus I have the cummins so I am pushing more HP/Torque. And I also have property in South FL (WPB area) and tow in the heat often enough. Also take into account that thedodgetransmissions of this generation do not pump fluid in park, and barely when stopped in drive.
Also make sure that you are purchasing a cooler with the proper sized lines (AN-8 =1/2", AN-6=3/8") if you restrict the flow of fluid you will do more damage than good. Keep in mind line presssure, those kits you posted use hoses and clamps, not something I would rely upon, you can have a local supply house press the proper ends onto a line for you (AN fittings) and never worry about popping off the line held on by a rusty tin hose clamp.
And yes I run a Derale cooler, and a Derale pan. Just my .02 hope it helps.
Derale Pan - http://store.summitracing.com/partde...p;autoview=sku
ap0x
Old Apr 11, 2008 | 10:59 AM
Mudbone25's Avatar
Mudbone25
humm.. those are a bit more expensive then the ones weve been talking about. For me its less about towing and more about extending trany life. Id rather spend 55 bucks then 180
Old Apr 11, 2008 | 11:03 AM
padodgeram's Avatar
padodgeram
has any one look at there local parts store ?? thats where i got mine for 48.00 buxs , rated at 18,000 GVW. Thats more then enough.
