Hood pin?
Old Apr 10, 2008 | 06:00 PM
IndyRamMan's Avatar
IndyRamMan
Default Hood pin?
Anyone have any suggestions on how to get hood pins to stay straight up and perminantly in that position? My hood latch has been getting stuck and causing me headakes, not to mention comming undone on the highway (not related to the repair, always has...yes iv gotten it replaced under the recall). I decided to get rid of it and just use hood pins. I am having trouble keeping them straight up and down, they like to angle off. I cant tighten both nuts flush because it will cause the pins to be at an angle. Aside from cutting washers up as angle shims is there anything else? Sorry for the dumb question, first time Iv used pins.
Old Apr 10, 2008 | 06:48 PM
mstephen89's Avatar
mstephen89
Default RE: Hood pin?
on race cars they weld them
Old Apr 10, 2008 | 09:05 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: mstephen89
aside from that.
Old Apr 10, 2008 | 09:36 PM
aim4squirrels's Avatar
aim4squirrels
Could you trim a heavy rubber grommet at an angle and then cinch thenut up snug against that? Either that or grind down some sort of aluminum spacer to contour to the hood and cinch that up for strength.
That's all assuming I'm envisioning your dilemma correctly.
Old Apr 10, 2008 | 09:57 PM
padodgeram's Avatar
padodgeram
right on dude .. thick rubber grommet cut it for the offset , really that your only choice...
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: aim4squirrels
You got it. I already tried the rubber, but it just moves out of the way when I tighten it or it squishes. Im probably just going to use washers as spacers and grind them to match the contour. I just dont want to waste time doing something so pointless. Iv had a string of that lately.
Old Apr 10, 2008 | 09:58 PM
engineblock's Avatar
engineblock
get a hammer and on that thing across the radiator make a dent that is even so the pins wont angleif u know what i mean, keep me informed i want to do this myself, i did it on my mustang but i used a hammer once tightent to bend it upright
Old Apr 10, 2008 | 10:26 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: engineblock
i gotcha. I was thinking of doing that, but Id rather do as little damage to the truck as possible. I guess basicly I just want someone to do it for me HAHA! Tomorrow Ill get to work on those spacers.
Old Apr 10, 2008 | 10:33 PM
hometheaterman's Avatar
hometheaterman
Why not just weld them?
Old Apr 10, 2008 | 10:38 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: hometheaterman
A: I dont have a 220 source to plug my welder into.
B: since I dont I havent learned how to weld yet.
