pvc valve
Old Apr 10, 2008 | 09:40 PM
engineblock's Avatar
engineblock
Default pvc valve
i was just gonna ask if we need the Pvc valve because i am planning in replacing it with a breather
this pic i found in the forum
Old Apr 10, 2008 | 09:49 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: pvc valve
that's the fresh air breather, the PCV can spit up some nasty stuff on the odd occasion (regulates ehaustas pressure and recirculates back into the intake) and the might plug that breather quick. Mopowar was having issues with his PCV a long while ago, he rigged up something to fix it, can't remember what though.
Old Apr 10, 2008 | 09:54 PM
jagxtype's Avatar
jagxtype
PCV=Positive Crancase ventilation... Keeps blowby out of the crankcase to keep your oil cleaner and reduce so much carbon buildup.
Old Apr 10, 2008 | 10:17 PM
Mudbone25's Avatar
Mudbone25
that breather isnt for the pcv valve. The pcv needs vacume from the manafold for proper ventilation. That breather replaces the hose that went from the top of the valve cover to the stock air hat.
Old Apr 10, 2008 | 10:41 PM
rabbler's Avatar
rabbler
There really isn't a reason you can't remove the PCV valve.
Buy you might get some oily residue or smell as the crankcase is nowvented to the engine compartment.
What's your reasoning for wanting to remove the PCV?
Old Apr 10, 2008 | 10:46 PM
jagxtype's Avatar
jagxtype
i think he meant breather for an aftermarket air cleaner...no harm with that unless you have excessive blowby.
Old Apr 10, 2008 | 10:52 PM
hometheaterman's Avatar
hometheaterman
Thats not the PCV valve. Thats the crankcase breather tube. The PCV valve is on the other valve cover. Anyway why do you need to remove it? I'd leave it alone. I do however have one of those breathers like that on my truck just not to replace the pcv valve.
Old Apr 11, 2008 | 12:34 AM
jagxtype's Avatar
jagxtype
Read my above post HTM...
