Fuel pump ???
Old Apr 12, 2008 | 08:38 PM
Nate749's Avatar
Nate749
Default Fuel pump ???
This is my ordeal. Just bought a 2000 2500 5.9 gas 4x4. Now my fuel pump stays on after I turn the truck off. Do I need to replace to fuel pump or relay or what. I am undoing the negative batt cable so it wont drain the batt. It also has 135k on the clock. Any help is appreciated I am kinda stumped.
Old Apr 12, 2008 | 10:50 PM
phlash_riot's Avatar
phlash_riot
Default RE: Fuel pump ???
not the fuel pump if it getting electricity when its not supposed to be getting it. relay; but i belive there are two possible relays that it can be. I'll get back with more info.
Old Apr 13, 2008 | 01:47 PM
motorbrreath's Avatar
motorbrreath
id check the relay. if the relay isnt cutting the pump off, the relay is bad.
Old Apr 13, 2008 | 01:55 PM
Nate749's Avatar
Nate749
Ok I will check that out. But where is it located at??
Old Apr 13, 2008 | 02:34 PM
Jr. Mechanic's Avatar
Jr. Mechanic
In the PDC (power distribution center.) While the pump is running, just pull the relay and see if it shuts off. If it does not, something is seriously rigged...
Old Apr 13, 2008 | 02:48 PM
dhvaughan's Avatar
dhvaughan
pdc is under the hood, drivers side, next to the battery. black plastic box with a cover that pulls off. diagram of relays and fuses on the underside of the cover.
Old Apr 13, 2008 | 07:45 PM
Nate749's Avatar
Nate749
It was the relay!!!!! Thanks guys
