96 Ram Halo High Beam Headlight
Old Apr 19, 2008 | 10:54 PM
CalMed's Avatar
CalMed
Default 96 Ram Halo High Beam Headlight
Just bought a halo headlight kit for my 96 Ram. When I hooked up the lights and turned the lights on, the high beam light on my dash stays on constantly, low or high beam on. Though a used kit, the wiring was from the factory. All I had to do was plug them in. What's the problem?
Old Apr 21, 2008 | 09:24 AM
Bhanson's Avatar
Bhanson
Default RE: 96 Ram Halo High Beam Headlight
Take the plug on the halos and you have to switch the pins in the plug to match the wires on the plug from teh truck..On mine i had to switch the blue and black wires around on both plugs.
Old Apr 21, 2008 | 03:10 PM
CalMed's Avatar
CalMed
yea i figured that out yesterday i broke out my test light and ound that out, i didn't switch the pins i cut the one of the two black wires going into the middle pin and ran it to a ground on the body and it work perfect.
Old Apr 8, 2012 | 08:33 PM
Jackstand123's Avatar
Jackstand123
Thanks for the post!! I searched and in 1 hr I found the solution and fixed it!! Thanks guys!
