nightmare???
Old Apr 21, 2008 | 11:34 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Default RE: nightmare???
ORIGINAL: CySlyde
the clips, and screws in some cars are mostly there to keep the rotors on while it's traveling down the assembly line. for the most part the rule I run with is no replacing the clip, yes replacing the screws. havn't had any issues to date.
+1. They are only there from the factory to keep the drums/disks on during initial assembly. When you tighten your lug nuts sown, they hold the drum/disc in place. I've never re-installed them as I usually just break them off as it is easier than trying to unthread them during disassembly.
Old Apr 21, 2008 | 08:41 PM
erikb45's Avatar
erikb45
you should sell that pad on ebay!!! [sm=partyparty.gif]
Old Apr 21, 2008 | 08:44 PM
CySlyde's Avatar
CySlyde
That looks like failure to me. he should be getting a free replacement, or at least discount on better pads regaurdless of warrenty
Old Apr 21, 2008 | 10:59 PM
jperkins812's Avatar
jperkins812
Was that the inner or outer pad that is in the picture?
Old Apr 21, 2008 | 11:25 PM
tresvn's Avatar
tresvn
that was the outer pad, when i pulled the wheel the caliper was sitting on the rotor.
