Deep Trans Pan
Old Apr 21, 2008 | 06:36 PM
TIMIDONE's Avatar
TIMIDONE
Default Deep Trans Pan
So I was reading Silver Dodges post for TOTM (congrats again btw) and he mentioned he has a deep trans pan....why? Still learning here so I was wondering why he did or what are the advantages? Just a curious mind wanting to know.
Old Apr 21, 2008 | 06:54 PM
padodgeram's Avatar
padodgeram
Default RE: Deep Trans Pan
Keep the fluid cooler plus it comes with a drain bolt . So if you do any type of towing , hauling , oversize tires that will produce more heat then normal then the deep pan will help , cooler trans is a happy trans... PML deep trans pan
[IMG]local://upfiles/40785/62D42BAFBB904041AFE81E3F6A2648C5.jpg[/IMG]
[IMG]local://upfiles/40785/B04F6BF2C22A4C35969666EC283D6C03.jpg[/IMG]
Old Apr 21, 2008 | 10:03 PM
Silver_Dodge's Avatar
Silver_Dodge
Yup, more fluid tends to help keep temps lower. This can be a double edged sword though because if you do get hot, more fluid is also harder to cool. I think the pros outway the cons though. I have that same PML pan.
Old Apr 21, 2008 | 10:17 PM
rabbler's Avatar
rabbler
With that pan do they give you any extension or adapter to drop down the filter?
Or does it mount in the stock location?
Is the drain plug magnetic? I assume the pan is aluminum.
Good lookin pan though.
Old Apr 21, 2008 | 10:33 PM
padodgeram's Avatar
padodgeram
no adapters , filter stays at the stock location , the drain plug ahas a magnetic tip , Sand-cast aluminum ... http://www.yourcovers.com/tp_9393.shtml
http://www.airram.com/product.php?ca...;productid=168 <-- Of course with the help of siver pointing me to the right direction of getting this..
Old Apr 21, 2008 | 10:44 PM
rabbler's Avatar
rabbler
Both look good. They look deeper than just an inch over stock though.
Worth it just for the drain plug and the stiffer sealing surface.
Old Apr 21, 2008 | 10:46 PM
RamItOne's Avatar
RamItOne
IMO this is better. even has a manual on off switch as well as auto at 180F
Old Apr 21, 2008 | 10:50 PM
padodgeram's Avatar
padodgeram
already have the trans cooler , the pan is just iceing on the cake
Old Apr 21, 2008 | 11:04 PM
RamItOne's Avatar
RamItOne
well sure doesnt everyone have an aux tranny rad stock? this hooks into it, not supposed to replace it, so you have your stock aux tranny cooler + another tranny rad with its own fan...
Old Apr 21, 2008 | 11:13 PM
padodgeram's Avatar
padodgeram
sure does , mine runs thru the rad then thru the aux cooler , no harm in that ..
