Trans problems????
Old Apr 27, 2008 | 11:40 PM
sam18142's Avatar
sam18142
Default Trans problems????
I have a 97 dodge ram1500 4x2. My problem is that when my truck is in overdrive it makes a whinning sound from the transmission. Only when is in overdrive. what do you guys think it will be???
Old Apr 27, 2008 | 11:45 PM
rabbler's Avatar
rabbler
Default RE: Trans problems????
Overdrive Planetary gear set.
Better get it checked out! It might be a symptom of a more serious condition.
Old Apr 27, 2008 | 11:48 PM
padodgeram's Avatar
padodgeram
Last thing you want to do is burn up the overdrive gear...LMAO ...
Old May 1, 2008 | 10:21 PM
Bam24609's Avatar
Bam24609
Im guessing you have a 4 speed auto with over drive?
you might want to turn overdrive off and get it checked out ASAP, dodge has been known for bad transmissions, if you have to replace it i would check into other compatable makers, stay away from a replacement.
Does this whinning sound go away after you slow down to 35 mph or lower?
Old May 2, 2008 | 02:16 PM
sam18142's Avatar
sam18142
ORIGINAL: Bam24609
yes you're right.after slow down the whinning sound go away.
Old May 2, 2008 | 04:40 PM
kowboydmac's Avatar
kowboydmac
I had mine overhauled because of a suspected OD gear being burnt out. Since then it's ran fine, just shifts a little weird, but that has more to do with me and the way my foot hits the accelerator in attempts to go fast or save gas, lol.
Old May 4, 2008 | 09:29 PM
Bam24609's Avatar
Bam24609
haha lol dude if you are experiencing wierd shift points or just tired of stock ones just get the ProComp Truck Computer upgrade downloader. it work great 3 stages, you can change shift points and shift firmness and get more horsepower and torque. i have it on stage 2 on my truck i get up to speed so much quicker and save a little on fuel. procomp is only one brand of course, find one that you like
