valvetrain noise after oil change
Old Apr 28, 2008 | 01:08 AM
cdusthockey's Avatar
cdusthockey
Default valvetrain noise after oil change
i recently changed my oil from valvoline 5-30 to mobil-1 5-30 and i am hearing what sounds to be like a whining noise when i am at idle and when i give it some slight throttle. i guess i am just wondering if anyone else has noticed something like this as well. the truck still runs fine
ohh 1999 5.9 w/160xxx miles
[IMG]local://upfiles/26220/B10BEACE88F143359B5C3D809D99F987.jpg[/IMG]
Old Apr 28, 2008 | 01:56 AM
froesen's Avatar
froesen
Default RE: valvetrain noise after oil change
Some motors don't like some oils as much as others, it seems. Could be the oil...that said...check your idler pulleys maybe?
Old Apr 28, 2008 | 01:57 AM
froesen's Avatar
froesen
although i've never been entirely sold on the "different engines like different oils", but my truck doesn't seem to like quaker...more lifter noise.
Old Apr 28, 2008 | 12:13 PM
Baddnet's Avatar
Baddnet
ORIGINAL: froesen
Have to agree.. last time I changed oil." castrol ". I bought a bouch<spell check... oil filter.. and now when I start the truck.. I hear valve train noise.. the fram filter didnt do that... it goes away in about 7 seconds.. but it drives me nuts...
Old Apr 28, 2008 | 11:30 PM
pipeking's Avatar
pipeking
i use castrol syntech and moble 1 filter and love it. castrol syntech cuz it has the coolest lookin quart and moble 1filter cuz it the only one ive seen spacificly for synthetic oil
Old Apr 28, 2008 | 11:40 PM
cdusthockey
well i can get mabile 1 for only a dollar more a quart than regular dion oil from a buddys shop, so i think ill just keep running it. Im planning on changing my oil every 6000 miles, so in the long run ill be saving some money.
Froesen, how exactually go about checking my idler pulley? can i feel the slop in it if i wiggle it or is it easier to just get a new one.
BTW
Anyone want a 99 dodge??? i need a car
Old Apr 28, 2008 | 11:52 PM
rabbler's Avatar
rabbler
Always, ALWAYS buy your oil based on the cool looking container!
There are lots of other filters that are excellent for syn oils. The Mobil 1 filter is an excellent design though. Only filter I can think that is better is possibly the new Amsoil filters but I think they are both made by the same company.
Old Apr 29, 2008 | 02:48 AM
froesen's Avatar
froesen
Take the belt off by using a wrench on the spring-loaded idler (passenger side) bolt, push it in and pop the belt off the alternator...with the spring tension released, spin that idler and the one located inbetween and below the alternator and a/c compressor. if they're bad, any parts store has them, easy swap. spin your alternator and w/p while you have the belt off.
Old Apr 29, 2008 | 06:59 AM
98DodgeRam1500's Avatar
98DodgeRam1500
I am using Quaker State High Mileage oil and my valve ticking went away. I got it because it has an additive that is supposed to help the oil seals from drying out. I also noticed my front main seal doesn't leak anymore.
I was a doubter, but I guess its working, another oil change or two... and I will check it again. I did get WIX Oil filters, and will not get those FRAMS. When I took mine off I turn it upside down to let the oil drain out and I saw something that looked like paper/cardboard shrapnel. I change my oil every 3K. I drive all backroads and rarely go over 55mph, 2000 rpms, and only 245 miles a week. So, I guess I might be changing my oil a little early, but its old and doing it myself is cheaper. This big turd truck has to last forever!!
