5.2 or 5.9
I just found out that the guyI bought my truck from has change engines before I got it from him. He also was not sure if the guy that did the work put original 5.2 or chages out the motor to 5.9
Is there a stamping/casting on the side of the block that would tell me what size motor this is??
Is there any other way to tell exactly which motor I have?
Thank you,
Thank you,
The engine serial number is stamped right into a machined pad located on the left, front corner of the cylinder block.
I.e.
X M AAA YYYY 0000
X = Last digit of model year
M = Plant
M Mound Road
S Saltillo
T Trenton
K Toluca
AAA = Engine displacement (CID)
YYYY= Month/Day
0000 = Engine Serial Code
I.e.
X M AAA YYYY 0000
M = Plant
M Mound Road
S Saltillo
T Trenton
K Toluca
YYYY= Month/Day
I could not find any machined pads with any numbers.
I foundsome numbers (cast)on the driver side of the engine block
All I could make out is some 5-6 digit number then space then 318 space some other number.
Does this mean that this block at least started out as 318?
