Stock tranny cooler
Old May 5, 2008 | 10:34 PM
timsalas's Avatar
timsalas
Default RE: Stock tranny cooler
aim4 is right , I checked and there's. A 'cute' wittle oem tranny cooler between the ac thing and the radiator ,
Old May 5, 2008 | 10:36 PM
timsalas's Avatar
timsalas
Which explains why the two pararell metal tubes where warm
Old May 5, 2008 | 11:26 PM
hometheaterman's Avatar
hometheaterman
Ok I didn't notice those tubes the first time when I glanced at your picture. So was my cooler I had mounted infront of the radiator aftermarket? I always assumed it was stock but I heard one other guy say his cooler was mounted inbetween like those. The one I had was mounted on the front in the same location my B&M is now.
Old May 6, 2008 | 01:27 AM
jasonw's Avatar
jasonw
Site Moderator
Mine's mounted in the very front as well, hometheaterman. Ours are both 2001s, maybe a difference between model years?
Old May 6, 2008 | 01:42 AM
rabbler's Avatar
rabbler
All the stock ones I've ever seen (2nd gen)were mounted between the rad and condenser
Old May 6, 2008 | 02:35 AM
jasonw's Avatar
jasonw
Site Moderator
Correction, I believe I found mine where its supposed to be. My apologies...
Hometheaterman, yours must have been aftermarket I'd say.
Old May 6, 2008 | 09:29 AM
dusty_duster's Avatar
dusty_duster
ORIGINAL: aim4squirrels
you HAVE and Aux tranny cooler.
Those 2 parallel hard lines running behind the AC condenser at a 30* angle go to it. If you peek between the rad and condenser you'll see it. It's about a quarter the size of the rad and sits bottom lower quadrant on the driver's side.
+1
You have a transmission cooler. It is between the condenser and the radiator.
Old May 6, 2008 | 10:13 AM
ramit2001's Avatar
ramit2001
On my last oil change I found trans fluid all over the front by the radiator and found out the there was a leak coming from the trans cooler. I seeled it up with some epoxy for now and am looking for a good aftermarket one. This is just way too small.
Old May 6, 2008 | 11:06 AM
hometheaterman
ORIGINAL: jason.w
Yeah I know another guy with a 01 Offroad and his was mounted inbetween them. I just always thought mine was stock as it looke basic and stock but I guess it wasn't. Anyway It tall got replaced anyways so it doesn't really matter too much I don't guess.
Old May 6, 2008 | 01:06 PM
dusty_duster
ORIGINAL: ramit2001
Do you have a transmission temp gauge? If not, how do you know it's too small?
I've got a transmission temperature gauge and the stock cooler. During normal driving, the transmission temperature never gets above 150*F. Even while towing a 5,000-pound trailer around Pennsylvania's mountains, the temperature never got above 180*F.
The stock transmission cooler is sufficient for most people's needs. But if yours is leaking, you should definitely replace it.
