Stall at Idle.
Old May 8, 2008 | 10:36 PM
  #21
Mudbone25's Avatar
Mudbone25
Default RE: Stall at Idle.
I reset my pcm when i replaced my IAC. The comp stores the settings for sensors and when you switch out to a new sensor its just going to be giving it old information.
+1 on cleaning the throttle body. I just did this a couple days ago.
Old May 10, 2008 | 12:15 AM
  #22
RangerMateo's Avatar
RangerMateo
ORIGINAL: chet
ya i seafoamed it when i cleaned it, one or the other helped ALOT but its still there. Smoked the whole block out haha.
2
I was doing mine and due to my low SA it happened to be around the time when they play the national anthem on base. Of course it started while I was mid can and now I'm standing there with my hand over my heart my truck rumbling and smoke as far as I could see downwind. It was awesome...
Old May 10, 2008 | 12:28 AM
  #23
IndyRamMan's Avatar
IndyRamMan
The blind leading the blind lol.
What was the situation previous that made you conclude you had fixed the problem, and what changed?
Old May 10, 2008 | 08:59 AM
  #24
aim4squirrels's Avatar
aim4squirrels
I think Indy's got a good point here, albeit a bit abrasive as usual. The big point I think is after warm up.
IAC would affect it from a cold start. I'm thinking it's something in closed loop causing the issue, but we'd need to know what you had exprienced before and what you attempted to fix.
Old May 10, 2008 | 01:43 PM
  #25
chet's Avatar
chet
before it was really bad and wouldnt hardly idle at all. to fix i cleaned the IAC and seafoamed it. It helped a little but still sputters.
Old May 11, 2008 | 04:32 AM
  #26
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: chet
Is it a sputter or a surge?
Quick check here. If you havent already check the connection on the IAC to make sure its snapped on. It may have been plugged in and not snapped down and come loose since you cleaned it.
Old May 11, 2008 | 11:51 AM
  #27
chet's Avatar
chet
its a sputter, but only at idle after warmed up. Ill check the connections but im 99% posotive its snapped in because i like triple checked everything after i did it. The intake also makes sucking sound when the truck is sputtering.
Old May 11, 2008 | 11:02 PM
  #28
RangerMateo
Mine had the exact same symptoms and the IAC / TB cleanout fixed it. There was a break-in type of period that it seemed like it was hunting for idle, but after about 100 miles it settled down just fine. As for the initial temperature corrolation, is it possible that the higher temps could have just softened up the varnish on the rod? Mine was pretty covered in nastiness.
Old May 11, 2008 | 11:25 PM
  #29
chet's Avatar
chet
how hard is it to clean the TB, and do i need to take it off to clean it ? what do you use to clean it with ?
Old May 12, 2008 | 12:13 AM
  #30
Mudbone25's Avatar
Mudbone25
Its not hard to clean/ take off. Theres a DYI on it that covers most of the job.
